Ricoh 1232C bad quality prints
  • Prodigal Son
    • Mar 2009
    • 161
    This one is really giving me a headache... I've got only a few of these machines in the field, and I have no training on them. My support can't help me much so I'm putting my trust in you guys!
    The prints have dots and lines (missing toner) all over them. See for yourself here: http://www.linford.se/serviceimages/ricoh1232c.pdf
    I've recently fixed a leak of siliconoil in the fuser, and I've replaced the drum cleaning unit. There are no obvious lines or dots on the dev rollers or the drum, and I've tried to remove any lumps around the dev rollers by sticking in a paper between the dev roller and the box, trying to mix it around a bit. The drum has made 95k copies so far, the fuser 44k, devs 35k.
    I can't seem to figure out what's wrong. My guess is the drum is somehow damaged, but is there a way to temporarily solve it or do I need a new drum?
    Peace sells, but who's buying?
  • Eric1968
    • 2458
    I would replace the complete PCU-Unit. Make sure the firmware is up to the latest (very important with this machine).
    • FRIDGEMAGNET
      • Aug 2007
      • 377
      These PCU's hardly ever make the 120k life so I would replace this first (don't forget the charge wire and grid).
      If you still have a problem then the dev units are next - your examples show cleanish cyan, magenta and yellow but the black has blank spots. This may be just the PCU though. Also seems to be streaking black through some colours.
      Good luck.
      • RicohTech_TurksCaicos
        • Aug 2008
        • 55
        Looks like you need
        B214 2302 Photoconductor Unit
        G070 2110 Charge Corona Wire
        G070 2156 Charge Corona Grid
        • Shadow1
          • Sep 2008
          • 1642
          Tell the customer to suck it up and quit complaining - that's about as good as these clunkers ever look.
          But if you insist on trying the PCU is shot. Black developer is a must, and the colors look to be cross contaminated as well but they may clean themselves out if you print several "blackouts" in each single color.
          Fuser is probably fine. Check the transfer for spots.
          Sorry you've been cursed with any of these.
          73 DE W5SSJ
          • Llama God
            • Mar 2009
            • 1353
            The black running could be a) contamination from it leaking down into the other ones after some bright spark designed this machine in the most ridiculous manner possible or b) the transfer drive assembly.
            I agree with Shadow1 though, these machines are truly dreadful. Go for an upgrade.
            • Prodigal Son
              • Mar 2009
              • 161
              Thanks guys, I've heard from just about all techs I know everywhere that these machines are the worst Ricoh ever made. I have actually tried to tell the customer he shouldn't complain as much, with the result I almost couldn't go back to him again haha funny story!
              • zyqwiz
                • Jun 2009
                • 333
                The life is 120k developments, not pages so if doing full colour all the time, it would do 30k pages.
                • CableGuy
                  Impulse Drive Engineer
                  • Oct 2008
                  • 417
                  We pulled another of these out of the filed last week and replaced it with a MPC, one less to worry about for us. Hope you get it sorted.
                  • Shadow1
                    • Sep 2008
                    • 1642
                    We had a program in our area to replace these - any zero book value color machine coming in off lease or trade in was fixed up and given to a 1224c customer. We might have been able to resell some of these machines, but in the long run this probably saved us a lot of money just on the happy customer / happy tech / good reputation theories.
                    We didn't get all of them, but we got the worst before we had to stop. It was causing somebody too much paperwork.
                    73 DE W5SSJ
                    • FRIDGEMAGNET
                      • Aug 2007
                      • 377
                      Ricoh are remanufacturing (factory refurb) these in the UK.
                      • Si@danwood
                        • Mar 2008
                        • 154
                        Give him the link to this and let him read it for himself, I am glad i am well shot of these awful, AWFUL machines
                        Si
                        • Llama God
                          • Mar 2009
                          • 1353
                          They suck balls
                          • Prodigal Son
                            • Mar 2009
                            • 161
                            We had 3 of these, plus a 3224c in the field to begin with. The first 1224 started acting up around a year after it was sold (sold as used). The copies had toner on the back of the pages, like if a cleaning unit was failing, so we changed drum cleaning unit, the clutch that engages the cleaning unit, the drum, some cogwheels and god knows what else but in the end the result was the same. We grew tired of it and replaced the machine. I've never ever felt so much satisfaction and joy, hell I could even have started to dance jig, as I did when the junkyard truck came to pick it up.
                            Only days after that the next 1224 started making bad copies. And a couple of weeks after that the 3224 did the same thing. We replaced them both, fixed up the 3224 with parts from the 1224 and resold it to a customer that didn't print as many copies, and with lower standards as well. They're all happier than ever and so am I.
                            When talking machine quality in the MPC series, I'd say the MPC3000 was less problems with, comparing to the newer MPC2800. I've had several issues with them, all from firmware to bad dev boxes, bad drivers, strange mechanical paper-folding issues and punch units gone wild. Wierd stuff, really. What's your opinion of it?
                            • E Winter
                              I think the sample looks quite OK for an A1224
                              The best solution is to hand over the case to the sales department. These machines sucks ass since the beginning and they still do PLUS they are getting older that's why putting a lot of money into these buggers isn't really economical.
