One of my printer customers dropped his service contract with someone else and now wants me to service this for him. The machine jams every page as it is leaving the fuser. It seams to be stopping in what Konica calls a switch back unit, I think Ricoh calls it a bridge. I looked at a parts breakdown and if I were taking a guess, I would guess the solenoid is failing and not putting the gate in the correct position. Second guess would be a paper path photocell. My first move was to try and sell a new machine but since that fell through I need to fix this one.
Ricoh Aficio 1035 jams after fuser
The default position for the exit/duplex gate is to exit the machine. If it's jamming on the exit and there is no physical stoppage of the paper, the exit sensor is likely bad. If the jamming occurs when duplexing, the gate solenoid is likely failed. I've seen both conditions as the unit sits directly over the fuser. Hope this helps.the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
Michael Bolton: You and me both, man. That thing is lucky I'm not armed. -
It helps. There is nothing stopping the paper so I guess that means the gate is in the correct position. I will look at the sensor. Do Ricoh photocells have a high failure rate? On the Minolta's , I may have about 1 bad one every 2 years.The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
One more thing before you go replacing parts, verify the paper size select dial in the back of the paper tray matches the size and orientation of the paper installed in the tray. If the incorrect letter size is installed (portrait vs. landscape) the machine will also jam in the fuser/exit section. Sometimes the papr make it out and sometimes it's still part way on the machine.the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
Michael Bolton: You and me both, man. That thing is lucky I'm not armed.Comment
The fail rate isn't bad. It's about the same age as a di250. So it's probably got 8-10 years worth of heat cycling. Start with the paper tray check first though.the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
good point, that would be about the point where the size of the paper would be measured.The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
The paper size has bit me several times and it's an easy fix (also easily overlooked)
If that's not it, machines this age have a bad rep for the fuser exit sensor going bad - its attached to the door, sits above the fuser in part of the guide and bakes. I can't remember offhand the jam code this sensor causes, but look in the SMC report to find out where the machine is reporting the jam.
Annother common fault is the duplex/exit gate tends to get stuck. There is a foam pad to keep the solenoid from clunking when it engages that gets sticky with age.73 DE W5SSJComment
E Winter
Annother common fault is the duplex/exit gate tends to get stuck. There is a foam pad to keep the solenoid from clunking when it engages that gets sticky with age.Comment
If all else fails, the cover over the interchange unit can be removed to observe the operation of the components in all its glory. At this point, the whole assembly can be lifted out.
The downside is you have to remove the scanner bed first. Not bad, just a bit awkward.Comment
Check the jam code on the SMC. If code 14, try the sensor in the Black unit at the top of the Right hand door which sits above the fuser when closed ((Fuser exit sensor). There was a mod for this sensor on the AF1035. I believe the modifed ones had a red exterior.Comment
If it has not been modified in the past, is that something that if I just ordered a new one I would get the modified one or would there be a special part number from a bulletin.The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
I have to agree with the sticky cushion theory. Usually that occurs early in the morning. It is called "morning sickness". I would also make sure that you have the correct springs on the solenoids. I have seen "makeshift" springs cause this problem too.
The jam code is "14", but by slightly bending the bracket, the sensor problem can usually be resolved. The reflectivity of the sensor changes that way. I think you bend it down slightly. You want to make it more square to the paper.Comment
What sort of state is the pressure roller in? They are always a jamming cause that is easily missed.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
