ricoh 3035 jamming
  • ash_572
    • 523
    ricoh 3035 jamming
    according to my logging data most of my jams are at 14.duplex exit 3. in the RTB it is the fusing exit sensor. does anyone know what can cause it to jam? or maybe there is a part that i need to replace.
    jams a this point at every 20-40 prints.
  • aabarnes1
    • Mar 2009
    • 620
    I've had these jams cuased by a number of things, usually dirty exit rollers, dry pressure roller, dirty duplex rollers or swithches in the bridge unit.
    Grant me the serenity to accept the things I cannot change.
    • msaeger
      • Sep 2008
      • 333
      Is it only jamming when on duplex. Maybe it's the pads on the solenoids for the exit junction gates.
      • RonMac
        • 57
        Jamming in Duplex Ricoh 3035
        Open up the duplex. On the inner door in the upper right hand corner is an accuator arm....check to see if it is broken. I have had this problem several times. When paper comes up through the duplex, it pushes the inner door out, which causes a jam if the accuator arm is broken. Hope this helps.
        • TonerMunkeh
          Professional Moron
          • 3865
          I'd go with that too. Is the pressure roller quite old?
          Hit it.
          • RonMac
            • 57
            Ricoh 3035 Jamming in Duplex
            Pressure Roller may have flat spots if it's old; if so, replace the pressure roller. Another place to check is the exit gate which is located over the fuser. The exit gate assembly has two solenoids which may have gone bad and are causing the jamming. Also check the spring that comes off near the solenoid on the right hand side. Spring might be dislodged causing the solenoid not to activate.
            • hodgiepodgie
              • 284
              mhm
              all good ideas but if you have fuser exit jams it wil be theinverter unit solenoids in most cases
              • stephend
                Senior Technician
                • 306
                yes...all good ideas but I'll go with the solenoids "sticky" pads or solenoids.
                Once I had this problem on a 15K unit and at the end was one of the invertor gates cracked...so until I removed from the machine I wasn't able to determine the problem.
                • wings
                  • May 2008
                  • 12
                  it is the dulex exit sensor (AW02 0158), you can replace it or re-solder the contacts in the sensor
                  • ivacopy
                    • 46
                    Hi
                    If only jam in duplex mode I had the same problem, change the solenoid and you will solve the problem.
                    • wings
                      • May 2008
                      • 12
                      i had this problem with 40 copies than it was jamming, replaced the 2 motors an solenoids but kept comming back, when on the data say's duplex exit it is most of the time this sensor.
                      • mikadonovan
                        • May 2008
                        • 2931
                        Most likely.
                        NEVER ASSUME ANYTHING
                        • wings
                          • May 2008
                          • 12
                          you mean the litle cusions on the solenoid in the paperseperation unit, over the fuser? then it won't go in the duplex, had that today!
                          • mikadonovan
                            • May 2008
                            • 2931
                            I think the reference is to the pads on the guides themselves to reduce noise. They get too hot and melt into a sticky mess and the solenoids try to fire but can't move the guides because they are stuck.
