Ricoh 1035
  • mike1025
    • 10
    Ricoh 1035
    I have a message SC542 please call tech support number#...., Please any one advice how to reset this message and fix the problem, thank you
  • copyguy5
    Ricoh Ra1035 Service Info
    You can find the Service Manuals at:
    Index of /protectedmembers/180903/RA1035_1045master/SERVICE
    GOOD LUCK
    copyguy5
    • jeffreyozz
      • Mar 2007
      • 52
      get into sps and turn off the main switch, when the machine reboots if there is no problem with the thermisters or the fuser itself it should be operational. air conditioning becomes a good source for these codes
      • Kopyrtek
        Copier Psychologist
        • Jan 2007
        • 407
        I have seen surge protectors cause this code also.
        • hosennet
          • Mar 2007
          • 145
          Hi
          Try next way:
          1. Input sp mode- exit- power off-power on
          2.Check Heater lamp-230v 550w 335mm (AX430072)
          Good luck
          • Herrmann
            • Jan 2006
            • 792
            Replace both Thermistors, they are known for being weak and cause much of Trouble.
            Regards
            Herrmann
            If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
            • blackthumb
              This is an "A" level code for Ricoh, and it usually involves the thermistors. I have seen this caused by a transparency wrapped into the thermistor, causing it to go out. Check continuity between one side of the fuser lamp contacts through the thermistors to the opposite side of the fuser. If continuity is present all across the fuser, reset the SC in the SP mode 7807, SC code reset. The machine must be completely powered off after you reset this code, then restarted to clear the code. You can also monitor the hot roller temps in sp 1106 (i think this is the right number, but the display will get you to the correct place) for both the roller end and center temps, once the SC is reset.
              • Tonerbomb
                AutoMajical Resolutionist
                • Feb 2005
                • 2589
                if this happened after replacing the hot roller you may have installed the wrong roller, this was very common a few years back.
                Mystic Crystal Revelations
                • BPGTECK
                  thats right tonerbomb thickness of the roller caused that problem
                  i remembered when i saw ur post
                  • mrvibe
                    same ole story
                    i have seen this problem several times. after reseting the code listen for any type clicking noises coming from the fuser unit... that will indicate your hot roller isnt a genuine ricoh part. you will see the roller starting to warp then crack, but before this happens you will get the sp popping up to warn ya...
                      • 23007
                      The SC542 is a fuser temperature warm up error. I caused this problem myself once when I installed an AF350 hot roller in an 1035. The thicker roller did not warm up quick enough to suite the main board. (Quick Start-Up Technology= thinner fuser roller).
                      • bluemax121
                        • 19
                        richo 1045 service manuel
                        hi
                        i have recoh 1045 5 mehines igot problam as sc440 in 2 mechins
                        plz help me to downlode a service manuel
                        kindly
                        thanqu
                        • etsmultan
                          • Apr 2007
                          • 131
                          reset
                          first go to service mode and then reset 5#801# and 5#810# and then if code appear 329 u hve to reset by 5401#
                          • etsmultan
                            • Apr 2007
                            • 131
                            reset
                            sorry reset by 5801
                            • imaginemoko
                              unTrusted Tech
                              • Jan 2008
                              • 289
                              check the thermostat if still has its continuity? if none replace same as the thermistor.... for time bieng go to sp mode turn off/ on the machine to reset the code.. but replace it as soon as possible..
                              fix the customer first then fix the machine... its simple and makes life more easy.
