Hi,
I have very strange jaming in A1035. Wheh te copier is cold in the morning they jaming on exit senzor. Always in the same position 1cm before comes out of copier. I check jams in SP mode and always is no. 14.
After 10 my be 15 jams when copier warmed they works without any problem!!!! Im not shure if this is mechanical problem becouse the paper stop just in the same position. I check exit senzor I thing is ok. Change transfer belt without beter result...
Do you have any similar problem with this copier?
Bostjan
Bostjan
