ricoh 3260<locked up sc-622 , 670,202,497,498. wrenchs at power on
  • scott beeler
    locked up 622 code
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    SC622 D LCT communication error
    Communication between the
    copier and LCT is interrupted.
    An ACK/NCK signal was not
    received within 100 ms after a
    data frame is sent and 3 retries
    failed.
    • Connection cable between the LCT and
    copier is disconnected, defective
    • LCT main board defective
    • BCU defective
    • PSU defective
    SC624 D Mailbox-to-copier communication error
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • spaceman99
      • Jul 2009
      • 174
      sc 622 caused by the cable in tray 1 LCT rubbing on the frame. causes itermittent fault sc622. NOT PCB's I had this Ricoh are now aware. repaired by taping of all the sharp edges.
      • tcs04
        FORMER Techie
        • 1183
        Had similar on AF2075, Blacked out the op panel. opened right tandem tray and fault cleared. check the loom behind the lower left corner of the right hand tandem cover, it can short against the centre support rail.
        • turbojetboy
          • Aug 2009
          • 279
          Hi spaceman, I have a MPC7500 that is at nearly 2 million and is starting to give intermittent sc622, it does seem to be related to the deck however for the life of me I cant see any worn thru wiring. Can you advise me where exactly you have seen the worn wiring? Cheers.
          • Vulkor
            • Jun 2009
            • 946
            Could be THIN Sheathing on the Wires too. You can have voltage leak throw a thin enough shielding with the proper metals.
