locked up 622 code
ricoh 3260<locked up sc-622 , 670,202,497,498. wrenchs at power on
SC622 D LCT communication error
Communication between the
copier and LCT is interrupted.
An ACK/NCK signal was not
received within 100 ms after a
data frame is sent and 3 retries
failed.
• Connection cable between the LCT and
copier is disconnected, defective
• LCT main board defective
• BCU defective
• PSU defective
SC624 D Mailbox-to-copier communication error
Communication betweenIBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications -
sc 622 caused by the cable in tray 1 LCT rubbing on the frame. causes itermittent fault sc622. NOT PCB's I had this Ricoh are now aware. repaired by taping of all the sharp edges.Comment
Had similar on AF2075, Blacked out the op panel. opened right tandem tray and fault cleared. check the loom behind the lower left corner of the right hand tandem cover, it can short against the centre support rail.Comment
Hi spaceman, I have a MPC7500 that is at nearly 2 million and is starting to give intermittent sc622, it does seem to be related to the deck however for the life of me I cant see any worn thru wiring. Can you advise me where exactly you have seen the worn wiring? Cheers.Comment
