Scanning shrink. anyone of you encounter?
  • aaalexxx
    Engineer
    • Jul 2009
    • 51
    hi guys,
    got 1 customer complain when scanning, the document shrink. at panel glass it's okay. but at ADF, the docment shrink. how do you guys resolved such issues.
    Thanks.
  • Eric1968
    • 2459
    Which model?
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      Clean the sensors
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • GhostInTheMachine
        • Feb 2010
        • 88
        When scanning to PDF the image will shrink about 3% I think. This is normal.
        • knightfall
          • Jul 2006
          • 633
          which model and how much shrink? maybe dirty original size sensors on the ADF.
          Get your facts first, and then you can distort them as much as you please.
          • msaeger
            • Sep 2008
            • 333
            The problem I see is people scan to a pdf and there will be a line on the side from the edge of the paper getting picked up. Acrobat's default printing settings is fit to page so then they print it and the page gets shrunk so the line from the edge of the paper will fit. If they just set it to not scale when printing they don't have a problem.
            • Choro1dal
              • Jun 2008
              • 176
              Have you checked to see if copies from originals fed through the ADF are reduced? I would suggest checking this and adjusting ADF sub scan magnification, lead edge and side to side registraions prior to anything else.
