I know we don't have an Infotec forum here, but given that they are a Ricoh manufactured device I figured this would be the best place!
I've got a little experience with the Canon copiers we have here on site, but this simple problem has me totally vexed. The copier loads fine, but when we try and run a copy the paper gets fed out of the trays fine runs up through the side door and then concertinas before it gets any further... The paper literally falls down as soon as you open the side door. I can't see any rollers or even an opening where the paper should be headed, partially because the door doesn't open nearly far enough to do anything constructive in there!
I don't fancy taking the door off just to get a better look in there becuase I'm guessing I'm not going to need to remove it to fix the offending item!
Any clues would be greatly appreciated?
Mike
Mike
