MPC 2500 Full Bleed on PS Driver?
  • techspec
    • Dec 2008
    • 128
    Is it possible?
  • turbojetboy
    • Aug 2009
    • 279
    Originally posted by techspec
    Is it possible?
    We have a mpc4500 that the cust set full bleed in the driver on and then after only a few pages had badly stained transfer ptr roller - causing marks on following pages. The facts are this model range (including 2500/3000/3500/4500) have NO cleaning mechanism for the PTR - so full bleed will end in tears. Why on earth it is allowed in the driver is beyond me.
    • Jomama46
      • 2900
      Full bleed should only be run when the copy paper is larger than the original. i.e. 11 x 17 onto 12 x 18 paper.
      sigpic
      A+; Network +; PDI+
      • TonerMunkeh
        Professional Moron
        • 3865
        Full bleed is a bad idea on an Athena. This family suffers from enough cleaning problems with general usage alone, never mind full coverage. A 25cpm machine doing the work of a Pro C900.
        Hit it.
