mpc5000
  • amps
    • Feb 2010
    • 6
    [CQ] mpc5000
    can anyone tell me if youi can source mpc5000 charge rollers as i have an issue with drums and cleaning blades being ok but worn charge rollers causing lines and spots etc thanks
  • barratec
    • Jun 2008
    • 162
    Charge rollers are not available like single part, the only way to change them is changing the whole drum unit.
    The only thing you can do for the issue is cleaning them.
    • zed255
      How'd ya manage that?
      • 1024
      The newer style rollers clean up well. I simply use a sturdy cleaning cloth and glass cleaner. I've tried other cleaners and I seem to get the best results with good ol' glass cleaner, a la Windex or similar. I've also experimented with the removal of the lubricant bar and have found that removing it after cleaning the charge roller a couple of time also helps. After all, the PCU is nearing end of life anyhow so why not crank it of everything its got?
