aficio 3025 squeeking
  • digicor
    • Jul 2008
    • 1159
    I have had it with this chirpping bird in this machine! does anybody have a solution to this ? i have wd40'd all the moving parts i can get to, still "chirp,chirp,chirp" sounds like is in the back of the dam thing.
    it also only has 34k . also have a mp2000 with the same chirp... please help, i have no wd40 left!! LOL
  • Fearless V K
    • 620
    Try to isolate the noise using output modes. Squeaks are the worst to locate sometimes. Probably just an idler gear or roller shaft bushing somewhere, depending on how deep in the squeak is, you may be looking at major dis-assembly to get to it. I have seen the toner supply unit squeak when it turns on these models, also the drum units can squeak from the development roller section.
    Don't take that toner with me!
    • digicor
      • Jul 2008
      • 1159
      thanks for the info i was afraid of the diss ass embly to kill a mockingbird! LOL
      • copyaction
        • Oct 2007
        • 991
        don't forget the white exit rollers
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          It is the white idler pulley that the little belt goes around that drives paper feed. Take back cover off and look for it right rear side. The pulley is riveted on so just a drop of oil will fix it (never use wd40 except to clean label glue off a cover)
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • digicor
            • Jul 2008
            • 1159
            thanks ill give it a shot
            • zed255
              How'd ya manage that?
              • 1024
              +1 for Venom. I've also had pulleys and gears in the main drive squeak, one pulley in particular, items #3 (AB01 4050) and #15 (B090 1111) on page 48 of the parts catalog. They ride on the same shaft and you'll hear the squeak if you run the main motor in output mode.
