sr4000 not stapling
  • slot
    • Jul 2008
    • 341
    sr4000 not stapling
    i have a sr4000 on a mp7500 that wont always corner staple what i mean by wont staple is it staples but misses the paper for some reason this is very intermitant any advice please
  • katash
    • May 2010
    • 221
    usually its the positioning roller belt out of position or the stalk feed out belt holder is off position,most common,hope that helps
    • Jomama46
      • 2900
      Also too much paper curl
      sigpic
      A+; Network +; PDI+
      • tcs04
        FORMER Techie
        • 1183
        Check for cracks in any guide mylars at the bottom of the stack area. Have had a similar problem on SR5000's but normally only causws the top sheet not to stack.
