Poor Fixing
  • tcypy1961
    • 773
    Poor Fixing
    Went to a customer with a Ricoh Aficio 1035 and they told me that they were able to wipe the print off their copies but only from time to time, it is an intermitent problem. However the copier doesn't error out when this happens. What could be causing this copier to do this? Any help appreciated, thank you.
    • 23008
    They could be using heavy paper stock, but not changing the media type. =^..^=
    • Jomama46
      • 2900
      probably damp paper.
      sigpic
      A+; Network +; PDI+
      • Vulkor
        • Jun 2009
        • 946
        Not often but possible flat spot on pressure roller.
        • andy1mack
          Senior Technician
          • Jun 2010
          • 17
          Check fuser pressure. I run two strips of paper through fuser by hand (one on front and one on rear). Pull paper through and see if there's an obvious pressure difference. Old trick - sometimes works.
