SC 555 Error code
  • bobk
    • Aug 2025
    SC 555 Error code
    I have a CL7200 with a SC 555 error code. What is giving me this error?
  • Choro1dal
    • Jun 2008
    • 176
    Probably a dodgy or dirty pressure roller thermistor.
    • bobk
      Thanks for the lead I'll check it out
      • bobk
        I checked the thermistor and it was dirty. I cleaned it and had the same error. The second time through I checked the ohms across the pressure roller lamp and got zero. I am going to order a lamp and a thermistor. Is there an underlying problem that I am missing?
        • Vulkor
          • Jun 2009
          • 946
          How close to PM time for the Fuser is it? It may be time for a new fusing unit anyways. Think you can print consumable time life left on that model.
          • delosangeles
            • May 2008
            • 274
            Here are the part #'s if you need them
            13 AX43 0146 Heater:120V:200W 1
            13 AX43 0147 Heater:230V:200W
            AW10 0103 Thermistor: Pressure
            Trade like a tiger sleep like a baby
            • RRodgers
              • Jun 2009
              • 1947
              You are SUPPOSE TO have 0 ohms across a lamp.
              • tcs04
                FORMER Techie
                • 1183
                1) Is the lamp open circuit? or 0 ohms? If o/c, are you sure the fuser didn't overheat and blow a thermofuse? If the thermistor was dirty this is likely to be the initial problem.
                2) have you reset the fuser code?
                • bobk
                  The pressure lamp was open. I replaced it and also replaced the thermistor. I checked the thermal fuses and they are good. Now I get a cl553 error. I reset the fusing unit counter and continue to get this error. Anything left to check?
                  • RRodgers
                    • Jun 2009
                    • 1947
                    I've been told that the pressure roller will get flat spots on it and needs to be replaced. I've also heard that it needs to be flashed as well to help keep these from happening.
                    HTH
                    • hodgiepodgie
                      • Jul 2008
                      • 284
                      THEROSTAT ALSO
                      • jonezy999
                        just one copy??
                        • Feb 2010
                        • 952
                        I know its already been stated, but have u reset the SC code??? Not the fuser counter.
                        I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
                        • mikadonovan
                          • May 2008
                          • 2931
                          You may have to replace the fuser. With the pressure lamp overheating even after you replaced the thermistor, you could also have a PSU or BCU problem. I would try another fuser first.
                          NEVER ASSUME ANYTHING
