Face up Print/Scan
  • farid
    • Aug 2025
    Face up Print/Scan
    Dear All,
    The Above Subject is Face up Print and Copy from ADF
    I have Nashuatec MP C 7500 machines in total 30.By dafault Print and Copy from ADF is face down, I want to change this default setting to face up. Please help me..
  • Jomama46
    • 2900
    UT>Copier settings> input/output>copy eject face method from glass (or something like that). Also one from Bypass
    sigpic
    A+; Network +; PDI+
    • Jomama46
      • 2900
      BTW, the reason it is face down is so sorted copies will be in the correct order.
      sigpic
      A+; Network +; PDI+
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Not to mention that the staple would be in the wrong position if you print face up.
        • farid
          Dear All,
          The same thing copy eject face up i need from by pass and all print job.
          • Jomama46
            • 2900
            call a tech, you need a new skatafritz
            sigpic
            A+; Network +; PDI+
            • farid
              hi
              [QUOTE=Jomama46;160691]call a tech, you need a new skatafritz[/QUOTE
              what is skatafritz.pls tell me in details.
              I am a tech.
              • farid
                i do not need sort please tell me how to make changes default.
                • Jomama46
                  • 2900
                  From the operator manual. UT>Copier settings> input/output>copy eject face method from glas. You cant change the ADF method.
                  sigpic
                  A+; Network +; PDI+
                  • delosangeles
                    • May 2008
                    • 274
                    Allow me to spoon feed
                    On the display on the upper left hand there is a real botton that has printed on it 'User tools / Counter" press that botton.
                    The touch screen will change and you will see soft keys. Touch the one that says "Copier settings"
                    The display will change once again and you will see several tabs, select the "Input/output" tab and you should see the setting for copy eject.
                    Easy huh?
                    Trade like a tiger sleep like a baby
