why do we need to update firmware of copier?
  • Gesttech
    • Oct 2009
    • 123
    [CQ] why do we need to update firmware of copier?
    Hi
    can someone told me why do we need to update firmware? All machine that my client have are ok, no need to update. for that i would like to know why do we update copier firmware & option? how to update firmware on sp mode, sd card, flash card, usb card.
    thanks
  • zed255
    How'd ya manage that?
    • 1024
    Firmware updates generally are for correcting 'bugs' in the code that is used as the machines operating system. Sometimes the updates are to correct a functional problem and sometimes they are enhancements to existing functions that are working fine. Generally if the machines are working fine then you leave them alone, but if there is something critical like a security or compatibility flaw it is wise to update.
    Do you update your computer's operating system? Some of the reasons for updating a copier or MFP's firmware are similar.
    As for how, I'd strongly encourage the use of a professional service provider. It is entirely possible with some machines and firmware modules to literally 'brick' the machine rendering it useless without replacing expensive boards. If you don't know how and have access to the firmware then don't even attempt it.
    • OMD-227
      Fully agree with everything Zed has mentioned.
      I was going to add that Firmware upgrades are made a reason. They are not made by the manufacturer just for the fun of it. After feedback from dealer & direct techs, manufacturers gather as much information as possible on the issue at hand, and if it can be sorted out by a software upgrade, then that is what is done.
      Sometimes its major system changes like timing of motors or sensors to prevent jamming, changes to how the machine processes a certain document type, changes to default fuser temperatures or system settings to increase performance, right through to silly things like fixing spelling mistakes in the user manual stored on the machines hard drive.
      Whatever the reason, firmware must be updated. I am completely against leaving a working machine as-is, because if you check the firmware revision update bulletins released when any update is released, there are obvious & very important corrections made to the machine & its operating abilities.
      There was one upgrade I remember a few years ago, that actually created a problem by installing it. The new version stopped direct USB printing of JPG files only, but would process everything else as normal. After giving feedback to H.O. this was quickly amended.
      Every single job I go to, the firmware is upgraded, even if it is only one version out-of-date. It is totally worth the 6 or 7 minutes taken to perform it, especially when it is as easy as plugging in a USB drive while you service the machine.
      • mrwho
        Major Asshole!
        • 4299
        Just yesterday I read about an update for the MPC2050. What did it fix? The precious software version could blow a fuse on the op panel, rendering it inoperable and forcing you to order a new one. Isn't that great?
        Mascan42
        Ibid
        • zed255
          • 1024
          I'm not disputing that updating the firmware *can* be important. I've never personally damaged a machine while doing it but a few co-workers have. Recent memory has one guy toasting an OP panel simply by being impatient and rocking the power deliberately and another damaged a controller board when the customer's power unexpectedly blacked out. I will update firmware when the release notes show something relevant to the customer's environment, not for every trivial release. I will also fully update a machine and retest for the issue prior to contacting tech support.
          • mrwho
            Major Asshole!
            • 4299
            You know what I call that? Upgraditis, a disease common to some techs - upgrade upgrade upgrade without taking into attention other factors. Sometimes can give more trouble than what it supposedly fixes.
            Mascan42
            Ibid
              • 23010
              Wow. What a contentious topic! I am of two minds on this subject.
              On the one hand:
              On certain manufacturers machines, a firmware update is a risky thing to do. Even when you do everything perfectly correct, I personally have crashed 1 of every 10 Sharp machines that I have ever flashed. The procedure has changed over the years, and I'm sure it's improved, but it's something to think about.
              Also, when one bug is fixed, quite often two new ones are created. And the new ones may be more devastating than thing fixed. A good example of this was version 3.60 firmware, on the Copystar CS-8030. Within hours of installing the latest firmware, every machine started to pull C4200 (laser unit) codes. For 6 or 8 weeks, and 3 versions of firmware, the only answer was to downgrade to version 3.52. To prevent situations like this from getting out of control, I install the newest firmware on machines in our office or nearby, and monitor them for a week or so, to determine if I'm creating more problems than solutions.
              On the other hand:
              The flashing procedure has become much more reliable. Since I've started working on Copystar, I may have crashed a total of (5) machines personally. While loading the firmware, the machine is at it's most vulnerable. A flicker of the AC power can brick your machine, and take a week to restore. Or if an enduser sees an unusual screen, and flicks the power Off/On to "clear the error".
              Proactively, you can save yourself a lot of trouble by keeping the firmware current. Problems that you didn't know existed can be solved, before they surfaced.
              So I guess I'm taking a more cautious middle ground.
              1) I always test new firmware on a handy machine for a week, to identify obvious bugs.
              2) Once tested OK, I do upgrade all machines as they are serviced.
              3) I keep all versions of firmware in reserve. If some strange new problem starts occurring on several machines of the same type, it's a good time to downgrade the firmware of a few test machines. I keep notes on specific firmware levels and driver levels so that if I go back, I know the limitations of each level.
              4) I strongly discourage amateurs from flashing firmware. It's the surest way to brick the machine if you don't follow the procedure to the letter. =^..^=
              • Mr Spock
                Vulcan Inventor of Death
                • Aug 2006
                • 2064
                I am with blackcat there are times that the firmware will fix issues and times it will hurt the machine. I wait 3-4 weeks before updating when a new release comes out. Then try it on something local first. Toshiba pushed a firmware update out and 2 weeks later found a big flaw in it. The individual maintenance counters could not be reset. Image copy quality issues because the controller uses the "life" of the components to adjust voltages, laser output, etc. And another tech coming behind you after a pm only to order the parts and redo it because the counters tell him to....
                A stand alone copier is the last to get an update unless it is relative to what they are doing.
                Network machine will be done after reviewing the "fixes" with the IT to see if they are relative to the customers production or if it will fix a known issue with that customer.
                • brodera
                  • Aug 2009
                  • 106
                  When i was a newbie tech, i did a firmware update and faild it and the machine briked for me!
                  We had to order a new NVram witch is kind of exprensive. I was not popular then
                  GL!
                  • RebelPhoenix
                    • Oct 2008
                    • 138
                    Sometimes a new firmware comes and solutions a problem.
                    For example,
                    Two years ago,
                    I installed a Ricoh MP 7500 with SR970,
                    Machines is continuous paper jamming. When I remove the sorter Machines is working good. After I taked notice ricoh is product a new firmware for this trouble SR970 paper jam. I update the firmware after machines is working good with SR970.
                    • verderacer
                      • May 2008
                      • 158
                      I too agree with blackcat and mr spock. I have personally experienced both sides of doing and not doing updates. I think a bit of prudence with good dose of common sense is always applicable in this kind of situation.
                      Ricoh & Microsoft may pay the bills but Un*x saves my ass every day.
                      MCSE/CCNE/ENS and other crap...
                      • KenB
                        Geek Extraordinaire
                        • Dec 2007
                        • 3944
                        New firmware versions are written for a reason, not just for laughs.
                        It's a good idea to have a copy of the old one, if available, so you can go back, but I can only remember one instance where new firmware broke the machine, and that was in 2001 on the Canon iR330 /400, and even that was a known issue.
                        Keep in mind that updates frequently fix issues that aren't even listed in their readme files. I remember a case many moons ago with a Canon fax, where the documentattion listed 29 fixes, but I found out from Engineering that there were actually 73 of them. The worst part was that the worst issue, where the machine would go into a "mini fax" mode, would occur only when the first 2 digits were "6-1". That fix was one of the unlisted ones.
                        If you call any tech help desk, they will ask you if the firmware is current. If it is not, they'll tell you to flash it all to current versions, then call back if the problem persists.
                        • mfa1
                          Re: why do we need to update firmware of copier?
                          my ricoh aficio gestetner3245 works but the screen says ( Please input user code then press # ) I tried with some codes but doesn't work finally it gives sc 990 it needs firmware how can I do that please
                          • sandmanmac
                            • 3983
                            This is a nearly 7 year old thread discussing a COMPLETELY unrelated topic.
                            In future, please start a new one.
                            1: You have obviously acquired this machine recently, because the "user authentication" issue you describe doesn't just turn itself on by itself.You will need to go into User tools/system settings and turn off ALL authentitications....That is, if the machine allows you to and doesn't have a higher level of Administration authentication enabled. That presents you with a whole new series of problems.
                            2: You get firmware from an authorized Dealer
                            3: This machine is ANCIENT, and I'm willing to bet that even if you do get access, it will have ALL sorts of other issues that will be EXTREMELY costly to fix
                            I could add to the list, but that's enough for now
                            • tech28
                              • Jun 2013
                              • 434
                              Like the old saying goes, "If it works, don't fix"
