Ricoh Aficio 1045 Folding paper in a 'Z' shape
  • Edutech
    • 16
    Hi, I have this machine that keeps on folding the papers after every few copies which are single sided. The paper folds before reaching the transfer belt since the folded section nearing the lead edge has no writings on it.
    In duplex mode it also forms jams in 'A', 'Z' and 'C' after a few successive copies.
    What should i do as it sometimes behaves while on other times it poorly misbehaves?
    Any help accorded shall be highly appreciated,
    EDutech
    "Everything is okay in the end, if it's not ok, then it's not the end."
  • duct tape
    • Jun 2009
    • 87
    Clean all clutches,paper feed transport and registration this should help
    • zed255
      How'd ya manage that?
      • 1024
      IMHO you should replace the feed, transport and registration clutches. Cleaning can help but new ones in my experience invariably work better.
      Clutch part numbers:
      Two pieces each AX20-0231 and AX20-0138, or I have been using these newer numbers AX20-0280 and AX20-0281 which may even supersede the prior numbers.
      Last edited by zed255; 08-26-2010, 01:16 PM. Reason: additional information: part numbers
      • mlanier
        • Jul 2010
        • 11
        Replaced all feed clutch's and reg clutch.
          • 23010
          I agree with zed. They are expensive, but will continue to be a nuisance until they are replaced. =^..^=
          • delosangeles
            • May 2008
            • 274
            Here here!!
            Here here, I second that conclusion.
            Trade like a tiger sleep like a baby
            • Edutech
              • 16
              Hi guys thanks to you all for your individual inputs. I like the seconding part, if the idea is as brilliant as this was. In short replacing these clutches worked miracles. This was very useful guys. Again thanks a bunch.
              Edutech
              • spaceman99
                • Jul 2009
                • 174
                Agree with the clutches. I would also replace the reg guide bar as static builds on this causing all kinds of jams and especially Z folds. Always works and never comes back until its worn again.
                good luck..........
                • zed255
                  • 1024
                  Edutech
                  You're welcome. It's always nice to hear back that a recommendation was helpful.
