Ricoh 3228c image defect
  • Copier_Guy
    • 543
    Could anyone give me an idea what may be causing a Black Block to print on the center of the page for this printer. I'm going to a client that has this problem and would like to expedite my troubleshooting process. Any help would be greatly appreciated.
    Thanks All
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Possibilities that spring to mind.
    1. A small scatch on the black drum (PCU).
    2. A small tear on the fusing belt.
    3. A leaking black dev unit.
    4. Dirty optics if it's on copying only.
    • Copier_Guy
      • 543
      Thanks for the response. I was thinking it might be density patch issue, but it might be a label or something that got adhered to the drum. I'll let you know after I get there and check it out.
      • Copier_Guy
        • 543
        It was actually a large Black Splotch going across the page. It turns out the Black Photoconductor Unit has seen better days. Needs replacement.
        Thanks DaZ for the input.
