Ricoh SP C232
  • Dark Helmet
    • May 2009
    • 856
    [Dead] Ricoh SP C232
    Hey guys, first time in the Ricoh forums! oh boy
    I have a brand new SP C232 right out of the box. Soon as i turned it on it gave a SC500 code. I turned it off and on and did a config page. Page made it about 2 inches out of the fuser and stopped. Fuser motor sounds abnormal. I pulled the fuser out, it turns very easy in my opinion. I pulled the fuser away from the gear and tripped the sensors and door and the fuser motor seemed to run ok. Is it possible I have a weak/failing fuser motor?
    I also ran into a SC300 but i had the front door open and tripped the switches. Not sure if the machine had issues since the transfer roller was not in place.
    Any suggestions?
  • zed255
    How'd ya manage that?
    • 1024
    Put it right back in the box and get something Ricoh actually made . But seriously, these things are absolute garbage. Our sales staff were damn near giving these away and when the customer finds out that a new fuser is over $500 for the part alone they generally don't even bother to fix 'em.
    • copyman20
      • 207
      Haven't been a printer tech for a long time, but, most ricoh (most printers for that matter) products have an inter-lock switch that shuts the fuser off when you open the door. When this switch starts to fails, you aways will either get door open messages, fuser warm-up errors, power supply error, or a combination of these.
      I hope this helps is some way.
      Good Luck
      • Dark Helmet
        • May 2009
        • 856
        Sounds like we are putting it back in the box. The motor almost sounds like it's surging. When i pulled it out first thing i thought was "peice of junk". Looks like a scary little machine to work on.
        Thanks for the suggestions guys
