Mp 6001 fuser codes repost
  • TONERINMYNOSE
    • Aug 2010
    • 114
    I keep getting sc 555, 542, 545 on this unit i have replaced the thermistors with the updated versions as well as the updated brackets, i changed the heat roller which had some wear on it, i am at a friggin loss here and the boss is riding me because this is at his lawyers office, any ideas?
  • Llama God
    • Mar 2009
    • 1353
    Have you replaced the thermostats? How long does the machine run for until the code reappears?
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
      Paul@justmanuals.com
      • txcharlie
        We have found what appears to be a solution for these codes. Change the following:SP1-103-001 to 60, 1-103-002 to 60, 1-103-003 to 120. Lower all fuser temps by 5-10 degrees. Hope this helps.
        Charlie
        • Llama God
          • Mar 2009
          • 1353
          I'd do the firmware too, just as a precaution
          • Ricoh-ono
            • 339
            http://www.copytechnet.com/forums/ri...html#post97242
            I followed the post by Kyle731 and it corrected my sc 555 problem.
            The sc 545 was resolved by replacing the fusing unit main harness/connector.
            Do what you can, with what you have, where you are. ~Theodore Roosevelt
            • TONERINMYNOSE
              • Aug 2010
              • 114
              thanks guys the problem is intermittent, about every 5-8k which is 2-3 days for them
              • emo
                • Feb 2010
                • 26
                I can't see Kylies response? what was it?
                • Ricoh-ono
                  • 339
                  This is what he said.
                  Step 1:
                  Check the lamp connectors (females specifically). From the factory they split and are not making good connection. I took my tweaker and pinched them so they were tighter. Depending on which lamp connectors are loose, you will get either 555 (fror the one lamp) or 546 codes ( for the other lamps). When I cheated the front door and would play with the lamp connectors I could get the machine to pop those codes, that is how i knew those connectors were an issue.
                  Step 2:
                  Per Ricoh, disable the 'panel off timer':
                  1) User tools
                  2) System Settings
                  3) Timer settings
                  4) Panel off timer, turn to off.
                  In addition to the info above I max out the energy saver modes. make sure all fuser idling modes are active, and use the latest thermistors (skinny ones).
                  • sg01
                    • 16
                    the part where kyle731 mentioned about the connectors is new to me. Got to try it out.
                    • TONERINMYNOSE
                      • Aug 2010
                      • 114
                      Lowered fuser temps, shimmed the rear fuser connector, so far so good. Anyone have the firmware for this thing?
