LD260C MP6000 Yellow Spots Due to Drum Damage
  • Harrison
    • Sep 2010
    • 10
    [CQ] LD260C MP6000 Yellow Spots Due to Drum Damage
    Found random pit marks (looks like impact) in random patterns on the drum. Different sets of dots and none of them go all the way around drum. Replaced all blades, lube bar and drum brush. Machine ran about 1 1/2 weeks and same marks are on the new drum. Any ideas?
  • mikadonovan
    • May 2008
    • 2931
    You might want to find out what the customer has tried running through the machine. Just a thought.
    NEVER ASSUME ANYTHING
    • techspec
      • Dec 2008
      • 128
      I had a strange one like this a few years back with pit marks on the OPC and it was narrowed down to the air con unit above the machine that was kicking out dirt that was landing on the by-pass tray and every time the customer used it the paper on the tray dragged crap into the machine. Shifted machine and issue disappeared.
      • Harrison
        • Sep 2010
        • 10
        Yeah, I have thought about that. Machine is in the mail room and the mail room guy is not sure what may have been run through the machine. The only thing that puzzles me is why there is no damage on the other 3 drums if someone has been running junk through. Also, the image transfer belt contacts the paper, not the drums. The ITB should have received the damage. That is unless something is sticking to the belt and riding around to the yellow drum.
        • BLADE
          former propeller tester
          • 478
          maybe something in the toner supply chewing out. lucky its yellow lol
          • NeoMatrix
            Senior Tech.
            • 3513
            [Just a thought]
            Is the machine used for high end colour photos ? Sounds like a clay-based paper is in use for glossy photos ?
            I had something similar to the above on a MPC5000: there where white "clay-like" lumps causing dev-roller voids in the developer unit. You could pick the lumps out of the dev unit and crush the white lumps with your fingers. No other tech I showed really knew exactly what the lumps where.
            We changed the developer and the problem went away...
            • Harrison
              • Sep 2010
              • 10
              Did the lumps put pit marks in the drum?
              • Tonerbomb
                AutoMajical Resolutionist
                • Feb 2005
                • 2589
                Sounds like bad developer.. also check your filters and fans, too much heat causes developer problems.
                Mystic Crystal Revelations
