I have 4 Ricoh 1022 copiers that have all had the same issue so I'm looking for a better answer than what I've been doing.
The copier will notify the user it is low on toner but when you change the toner the old one is not empty (maybe half empty). You install the new toner and the machine churns away for several minutes the says "Toner Low" again. If you keep opening and closing the cover it will keep cycling and finally the toner warning will go off but will come back on several copies later.
After checking everything and it all looking normal I replace the drum/developer unit and the problem goes away.
Is the toner sensor in the drum unit going bad before the life of the drum is up? Is there a problem with the toner or bottle that is not allowing it to tone up fast enough?
Just wondering if any of you guys have seen this issue and what you did to correct it.
Thanks for your help,
Tony
Tony
