Ricoh Aficio 1515 Ghosting
  • iscott
    • Mar 2010
    • 344
    Gosting image is occuring in the fuser pressure roller has been replaced springs are on correctly toner is ricoh brand.
    About ready to trash it. Or just replace the whole fuser.......
    If this makes any difference it is really a Savin 3515.....
  • CT Copier Repair
    • Mar 2010
    • 304
    is the image on the paper? Or on the roller? if on the paper then its a cleaning problem. If coming from the roller then its a toner or fuser problem. Try a different image unit is it still there?
    • iscott
      • Mar 2010
      • 344
      Sorry The PC Unit is brand new and the gosting occurs in the fuser not at the PC U.
      Also I miss Spoke the heat roller is the part that was just replaced
      • ricoco
        • Jan 2011
        • 122
        What is the temperature in the fuser?
        See the SP 1106-1.
        You also can change the temperature on the SP 1105-1 and 1105-5.
        • mongo59
          • Sep 2009
          • 3
          If the humity is high, bumping the fuser temp 5 degrees will some time fix it. Don't go higher than that or you will be resetting fuser codes.
          Mongo
          • halac0ax
            • 18
            Have you tried a different hot roller?
            • halac0ax
              • 18
              I just read your other post.. Try a different transfer roller
              • BLADE
                former propeller tester
                • 478
                check if there is a pressure release mechanism not working if the fuser was rebuilt
                • rthonpm
                  • Aug 2007
                  • 2859
                  Check the bushings for the pressure roller, as well as the pressure roller itself. In my experience, the press rollers in these don't always show visible issues, but a new one should do the trick.
                  • jonezy999
                    just one copy??
                    • Feb 2010
                    • 952
                    Pressure roller bushings x100.
                    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
                    • anthony123
                      • 62
                      So,,,, What was the fix ????
                      • Blazer1087
                        • 195
                        Is the hot roller OEM? we have had problems with aftermarket rollers on this model.
                        • ZeusGT
                          • 271
                          Pressure roller bushings... Make sure the frame of the fuser is not broken as well.
                          CompTia A+ Certified
                          CompTia Net+ Certified
                          CompTia Server+ Certified
                          CompTia Project+ Certified
                          OP Scanshare Certified
                          • stan780953
                            • Feb 2011
                            • 47
                            If you have only replaced the Hot roller I would also fit a pressure roller. This I think will 99% fix your ghosting.
                            • Venom
                              Technical/IT Support
                              • Nov 2009
                              • 765
                              I agree, up the fuser temp
                              IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
