Ricoh Aficio 450
  • Wullie1
    • Aug 2025
    Ricoh Aficio 450
    I have a AF450 with the add toner light staying on.
    I have located the fault to the main board.
    Question: Can this symptom be cleared from the main board.
    Any help would be appreciated.
    • 23010
    There are several simple things to check first:
    1) The toner hopper may be clogged.
    2) The toner motor may be shorted, blowing IC122 on the IOB. Replace the toner motor and IOB as a set (see TSB A680-035)
    3) The right doorswitch bracket may be mounted incorrectly (and does not display "Close Doors/Covers").
    4) Check to see if SP5-957 is set correctly. See (TSB232-032)
    Courtesy of Goose's.
    • Wullie1
      Thanks for your reply.
      I changed the IOB board and the toner motor assy., ...toner light still on.
      I replaced the main board, problem solved on customers machine.
      Now I have a main board that keeps the toner light on.
      I was hoping to put the faulty main board back into another AF450 and possibly reset it to, toner light off and then have a spare working main board.
      • jeffreyozz
        • Mar 2007
        • 52
        replace the main board nvram.
        • The Real JB
          Did Replacing the NVRAM Fix the Issue?
          If replacing the NVRAM did not fix the issue, or if it did, please let the community know.
