Ricoh MP7001 LCT Tray Lift wires
  • mrwho
    Major Asshole!
    • 4299
    I need the part number for the LCT lift metal wires, but they aren't numbered in the parts catalog. Can anyone point me in the right direction?
    Thanks.
    Mascan42
    Ibid
  • teebee1234
    • 1670
    If you meant the Tandem Tray, the lift wire assy is B2476694 (Pulley: Drive Wire: Ass'y) qty 2
    For the LCT, it normally uses lift belts, the only wires I found were for the A3 Paper Tray Kit 2 (B475), and they are listed as "Drive Pulley". I'll search further for clarification. B4756834 Drive Pulley (2)
    • jonezy999
      just one copy??
      • Feb 2010
      • 952
      This is from the mp7000 parts list.
      Chapter 22, part 19
      B247 6694 Pulley drive wire assy.
      It was spelled incorrectly in the manual. It says "were" instead of wire.
      I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
      • mrwho
        Major Asshole!
        • 4299
        Chapter 22, part 19
        I saw that and thought about it, but when I searched the pn on google, I only saw pictures of the pulley without the wire. Did you ever order these?
        Thanks.
        Mascan42
        Ibid
        • teebee1234
          • 1670
          Here is the blowout diagram. As Jonezy said, item 19. Is this what you need? This diagram shows the wires...
          • jonezy999
            just one copy??
            • Feb 2010
            • 952
            I see what you're saying in regards to the Google search. No, I have never needed to replace or order these. Do you have access to Ricoh spares? I can call them and find out exactly if you would like, but I'm fairly sure they come complete with the wires.
