Aficio 1035 developer unit rebuilding
  • muaazgujjar
    • 67
    I am trying to rebuild a developer unit of Aficio 1035. Magnetic roller has been parted from Doctor blade.Would anysenior one be advise the exact or minimum gap between Mag roller & doctor blade to maintain a resonable size of brush on the mag roller.
  • Jomama46
    • 2900
    Its factory set. You're not supposed to take it apart. Get a new one.
    sigpic
    A+; Network +; PDI+
    • muaazgujjar
      • 67
      Aficio 1035
      Thanking you sir,
      Many mistakes could be done.However one of my friend advised us to put 8 papers of 80gsm between roller and doctor blade and adjust the gap.The trick woked fine for me.I am of the view that its just a trick paper can be of different thickness (bulky or fine).
      But as you advised one must not deal with some factory setted parts in any of the units.
      • Lagonda
        • Aug 2008
        • 1649
        If the screw head has white paint on it, leave it alone!
        • ccchuah
          • Mar 2009
          • 157
          Why not you take other development unit of 1035, measure with the gauge and solve the problem youself ?
          • Gift
            • Mar 2011
            • 2459
            Try 3 or 4 sheets standard copy paper between the mag roller and doctor gap (I'd go with 3 sheets and if the blacks looks pale you can still increase the gap) - there's no need for a new unit if nothing else is broken.
            • nmfaxman
              • 1702
              Tight .35 mm.
