Part #'s needed
  • nmfaxman
    • 1702
    Part #'s needed
    Looking for part # of fuser knob on 3245C, parts book doesn't have it.
    Also need Part # of drum cleaning blade for MPC 4500.
    I can find a # for drum unit and drum kit but not blade alone.
    Thanks for any info.
  • RRodgers
    • Jun 2009
    • 1947
    Re: Part #'s needed
    Try Printer Toner Cartridges - Copier Toner Cartridges - Printer Parts & Copier Parts
    • jonhiker
      • 661
      Re: Part #'s needed
      TSB31.pdf
      The part number for the knob is: B101-4035.
      On the MPC 4500, as far as I know, the PCU only comes as a unit and the individual components cannot be ordered as seperate items.
      • londonboy
        • Jul 2011
        • 10
        Re: Part #'s needed
        You will not get the mpc4500 blade on its own, you only get with the drum unit or rob the charge roller/blade assy from another drum assy.
          • 23010
          Re: Part #'s needed
          Originally posted by jonhiker
          [ATTACH=CONFIG]11035[/ATTACH]On the MPC 4500, as far as I know, the PCU only comes as a unit and the individual components cannot be ordered as seperate items.
          Like he said. And they don't last the yield.
          • nmfaxman
            • 1702
            Re: Part #'s needed
            Once again....With a deep bow "HIROSHIMA". Thanks Ricoh.
