MPC4500 - Toner undetectable ??????
  • luca72
    • Oct 2017
    • 1748
    #16
    Re: MPC4500 - Toner undetectable ??????
    Originally posted by andrewdecruz
    Dear Friends,
    I have a Ricoh Color MPC4500 which shows "undetectable" in the Systen Status although i have just replaced a new toner cartriage. There is also a sign which shows " Independant - toner cartriage is set" which appears on the touch screen. However, the toner cartriage will stilll turn when the machine is printing. Appreciate your speedy reply.
    Thanks in advance. Cheers.
    sometimes happen a cartridge with bad chip that not show the bar level, you can only replace, or try to clean the chip conctact with alcool and a rag
    "I'll be back"
    • RicohBoomer
      • May 2022
      • 40
      #17
      The few times I've gotten this message(Usually because servicing required me to swap around toner bottles) I have just left it alone because the only thing it seems to do is warn you about "Independent toner" and remove the corresponding "Toner level" bar. I think it clears if you put in a new one and if it doesn't then it will surely clear once a toner runs out and you then swap to a new one.
      Can't you just tell the customer that nothing is really wrong, the only thing he'll suffer is not being able to tell what the toner level is.
      • copierkats
        • Nov 2012
        • 8
        #18
        Thanks for the reply! I actually did that, but they called for light copies, do I replaced the machine, I still
        have the mpc 4502, I might change the black developer, then see what I get.
          • 37379
          #19
          SP 5801-002. It's the worst part of SP 5801-001. That is why you need the birth certificate. There is another method but that requires knowing the exact memory address for the toner level affected.
          • Gift
            • Mar 2011
            • 2458
            #20
            I also tell my customer to ignore this message and offer them to send a spare in advance to they are equipped for the moment of a sudden "toner end" condition.
            Light copies is not to related to this.
            Back in the day when the MPC6000 was up to date I was able to revive toner bottles with detection issues this way:
            - backup nv-ram data -> SC Card
            - perform engine memory clear
            - restore nv-ram data from SD card
            If I remember correctly the MPC refuses to work with the toners at all so you couldn't run them with "no toner level indicator" limitation, otherwise I wouldn't have to run this kind of procedure.
            • RicohBoomer
              • May 2022
              • 40
              #21
              I have never had the toner itself be responsible for light prints. I assume this could happen with third party toner.
              However, this issue is likely not because of the toner. If you only have light prints using black then it is very likely to be the dev unit. If the drum unit is also nearing its end then you might as well swap them both together and save yourself future worry.
