Aficio 2018d Scanning problem
  • goldencup
    • Nov 2008
    • 366
    Hi! I would like to ask if the machine Aficio 2018d can be used as scan to folder? If there is, may I know the step by step procedure? by the way, I will use it only on Windows XP. I have already installed the Desktopbinder and the TWAIN driver. Thank you very much.
  • Meach
    • Nov 2008
    • 128
    Re: Aficio 2018d Scanning problem
    The 2018d does not support Scan to Folder/SMB.
    It will scan to EMAIL
    • goldencup
      • Nov 2008
      • 366
      Thank you very much for the response. So there's no way I can scan the document from the machine to computer? Only by using Desktopbinder, Scanwiz or other scanning application?
      • sandmanmac
        • 3981
        Is this related to your original thread started a couple of days ago?:
        http://www.copytechnet.com/forums/ri...8-sd-card.html
        Why not continue with the same thread?
        Scan to folder requires "scanrouter V2 lite" software (if you can still find it), as well as the knowledge of how to configure it, if you've not used it before, because it's quirky. You could otherwise setup "scan to FTP" which is more reliable IMO, or as stated above, "scan to email'
        • goldencup
          • Nov 2008
          • 366
          Thank you by the way, it is not related. On the other thread I was looking for a way to have another copy of the SD Card because my other machine doesn't have. Here i'm looking for a way if it's possible to scan from the machine to pc
          • nmfaxman
            • 1702
            The 2018 does support scanrouter. It can only be installed on one computer and share those folders out.
            Problem is that Ricoh no longer supports scanrouter, so you are on your own if there are problems.
            I have made it work on a Win7 32bit, thanks to input from this site.
            Good Luck.
            • femaster
              • May 2011
              • 1514
              Originally posted by sandmanmac
              Scan to folder requires "scanrouter V2 lite" software (if you can still find it), ...
              It is a bit tricky to get setup, as sandmanmac stated. Below is a link to the setup guide and the software. It's in a "public" folder, so you MAY be able to access it without authenticating to the site. Unfortunately, my computer is already authenticated, so I have no way of testing for sure. If you can't access the document or software, let me know, and I'll try to make other arrangements.
              EDIT: I've removed the link to the setup guide, as it appears that a newer version of the guide, and multiple other language versions, are included in the ZIP file for the software.
              • sandmanmac
                • 3981
                Nice link femaster. I'm surprised that Ricoh still has the software available on one of their sites (I wish I still had access).
                I've attached my own 1 page "Coles notes" version of the setup for Scanrouter. I've not seen the new setup guide within your download, but I've created this for many of my clients, to help them be more self-sufficient when the s*#t hits the fan, and save me some time.
                I think most will find it quite a bit easier to follow than RICOH's typical guide of the "land of confusion" anyway, plus it includes a few settings for windows XP not covered in the original setup guide, such as windows firewall port #3670:
                Scanrouter Setup.pdf
                • femaster
                  • May 2011
                  • 1514
                  Excellent document sandmanmac. Very helpful indeed, will be saving that to my collection. Always nice to have a step by step document like that; certainly makes things quite a bit clearer...
                  I'm sure you meant that you wished you still had access to the site, but if you want the software, and can't get it at the link, just say the word and I can ship it your way.
                  • goldencup
                    • Nov 2008
                    • 366
                    Just want to say Thank You for all your help
                    • sandmanmac
                      • 3981
                      No Thanks. I could access the link, but I've had a copy of the software saved for years anyway. It's the TSB's, firmware, and manuals for the newest equipment that I'm missing most since I got cut off.
