MP171 Can ping machine but no printing
  • Llama God
    • Mar 2009
    • 1353
    #16
    Re: MP171 Can ping machine but no printing
    Originally posted by mrwho
    Still, what error are you getting?
    I'd give up if I were you!
    • Gift
      • Mar 2011
      • 2459
      #17
      Some USB-based installations are hard to restore once something is messed up, expecially if there are no proper tools available that wipes all driver files (removing just the printer within windows doesn't neceesarily do the trick). I haven't much experience installing ricoh MFP's this way but I'd probably go with the installer-CD-dialogue instead of a manual installation via "add printer" - better get the software-manual and another computer (testwise) to see if it works with a neutral system.
      EDIT: Ohps - I was reading too fast - the machine DOES print via USB, kinda imagined something else so please forget all USB related thoughts of mine^^
      • Voltage
        • Jul 2008
        • 282
        #18
        If i open the printer jobs window, under printing status it says printing-error. No error is displayed on the machine display.
        • Llama God
          • Mar 2009
          • 1353
          #19
          So when you send a print job to the machine, does the data light flash at all?
          • Voltage
            • Jul 2008
            • 282
            #20
            Nope.
            Also is do not get that immediate "Failed to print" message. It takes a minute before giving the error
            • mrwho
              Major Asshole!
              • 4299
              #21
              Try to print using a network cable - if it doesn't print, then your print controller is most probably fried.
              If it prints via network, then try again to print via USB from a new PC (your laptop, for instance) to see if it does. Try with a new USB cable just for kicks.
              Mascan42
              Ibid
              • Voltage
                • Jul 2008
                • 282
                #22
                Hi.
                I can print using the USB cable but not through a network cable. The machine is in our workshop and also does not work through our network. I can ping the machine and the machine can ping my laptop. I do not know if the customer fiddled around with a setting or something.
                • fbkhan3
                  • May 2012
                  • 421
                  #23
                  hi
                  these models are hell bad with network when it comes to installation,as you said you can ping but can't print it surely not the GW bord,
                  either it's something wrong with driver or network,
                  Also you did'nt mention Machine spec
                  MP171LN, drive would be DDST
                  MP 171SPF PCL6 or PCL5e
                  make sure you Download the correct driver but don't run it,just extract the zip file and save a copy on desktop.
                  Try following few things to figure out,
                  Rule out the network and just hook it up to your Pc Via network cable,
                  machine ip 192.168.1.1
                  PC Local Area Ip, 192.168.1.2
                  ping the machine's ip to see reply
                  now click
                  start
                  devices and printers
                  add printer
                  click on add network printer and let the Pc search for available printer's.see attachments if you not familiar with that,
                  now browse for driver and patch the driver file,
                  after completing the installation select printer properties and set the paper size to A4
                  make a test print
                  give it a try,sure it works
                  • fbkhan3
                    • May 2012
                    • 421
                    #24
                    Originally posted by fbkhan3
                    hi
                    Try following few things to figure out,try peer to peer.
                    now click
                    start
                    add printer
                    make a test print
                    Pardon ,,correction you mentioned SPF model but missed that,this why i had to edit.
                    • Voltage
                      • Jul 2008
                      • 282
                      #25
                      When i try to create a port i get the following message:
                      but i can ping the machine.
                      • fbkhan3
                        • May 2012
                        • 421
                        #26
                        don't worry about that.did your pc find that printer as network printer with ip in earlier 2 step.
                        if it did then no problem,patch the driver file and complete the installation,,
                        • Voltage
                          • Jul 2008
                          • 282
                          #27
                          Yes it did find the printer in the earlier step. I did continue with the driver installation but still no joy.
                          • fbkhan3
                            • May 2012
                            • 421
                            #28
                            It's pretty strange,does this model contain a SD card?not familiar with this model but a year back i had the same issue with Mp2000LN...had to bring it back to workshop and it took 2 f....day's to make a print.
                            one more thing you can do is change the port from 9100 to 10001 or something like that.
                            I'm sure you missing the trick somewhere,
                            only thing you can do replace GW with other one and see if it works.
                            • Voltage
                              • Jul 2008
                              • 282
                              #29
                              Did swap the SD card with a other machine. Still did the same. I also think i am missing something.
                              • patterson70
                                • May 2010
                                • 599
                                #30
                                If you are hooking up directly to a PC without a router, shouldn't you be using a cross-over cable and using 169.254.x.xxx as an IP address? Please correct me if not...
