what does the music procedure do ?
  • Blazer1087
    • 195
    Re: what does the music procedure do ?
    Originally posted by Jomama46
    Reg will also be off if the density of the developer is too weak or if the ID sensors cannot register and that may be caused by the upper left roller in the ITB unit as the sensors read off of that. Or the ITB may be scratched.
    not many copies on dev or pcu. when i print the color test page from the printer service mode the colors are all exellent, just not aligned. I'm not at mydesk now so cant remember the sc but i did the one where you check results and they should be all 111111 and they were. I swapped with another transfer unit, same result.
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      The music adjustment is to adjust the C M Y mirrors to be parallel with K mirror in LSU.
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • Shadow1
        • Sep 2008
        • 1642
        There is a coarse and fine line position adjustment in SP mode - Not near my manuals now, so I can't look up the number. The adjustments in UT only do the fine adjustment, as does a normal ProCon, but sometimes it can get so far out of whack the fine adjustment wont correct for it.
        That's usually from a dirty ID sensor or worn ITB. Correct the mechanical issues, and bring the machine up to PM (anything that causes CQ issues other than the fuser can cause it to fail the adjustment) Run the coarse adjustment, then the fine, and test it.
        IIRC some of the machines call the line position adjustments A, B, and C. Don't know what adjustment B is, but the coarse is sub-code 003, and fine is subcode 001.
        If that doesn't work look up the SC code history, and post the codes for us. That should give us a pretty good clue as to what causes it to fail.
        73 DE W5SSJ
        • Jomama46
          • 2900
          #19
          IIRC?
          sigpic
          A+; Network +; PDI+
          • rthonpm
            • Aug 2007
            • 2857
            #20
            I'm not sure what IIRC is either, but I'm guessing it's: if I remember correctly.
            Oh for the days before instant messaging and SMS. Too many acronyms anymore to keep straight.
            • Jomama46
              • 2900
              #21
              Ain't that the living truth! Thanks
              sigpic
              A+; Network +; PDI+
              • Shadow1
                • Sep 2008
                • 1642
                #22
                Yup - sorry, thought that one was pretty standard.
                LOL... ROFL.
                Or here's one for you: ROFLMAOBCOMN
                Rolling
                On
                Floor
                Laughing
                My
                A$$
                Off,
                Blew
                Coffee
                Out
                My
                Nose.
                There's a whole dictionary of SMS shorthand at The Largest List of Text Message Shorthand (IM, SMS) and Internet Acronyms Found of the Web - kept current and up-to-date by NetLingo The Internet Dictionary: Online Dictionary of Computer and Internet Terms, Acronyms, Text Messaging, Smileys ;-) - Some of them are pretty funny.
                73 DE W5SSJ
                • Jomama46
                  • 2900
                  #23
                  Great! This is just what I need to interpret my nephews FB posts.
                  sigpic
                  A+; Network +; PDI+
                  • Llama God
                    • Mar 2009
                    • 1353
                    #24
                    This is wrong on so many levels.
                    • NeoMatrix
                      Senior Tech.
                      • 3513
                      #25
                      Me too...
                      I must be getting old.
                      I had no idea what IIRC meant. I had to ask my SMS social site mad Kids. They did'nt know either so I didn't feel so bad....
                      • luca72
                        • Oct 2017
                        • 1780
                        #26
                        Originally posted by SamHanson
                        Recently I found a website on the Internet where it is possible to download any audio from videos online for free. I thought I would never have a chance to get any content for offline listening until I found Tubidy. I recommend that you follow the link to the official website of this online software. This can be extremely useful for you, and therefore I think that you should bookmark the site so as not to lose it.
                        excellent, I see that they travel even with a high bit-rate!
                        "I'll be back"
                        • rthonpm
                          • Aug 2007
                          • 2857
                          #27
                          Don't encourage the spammer.
                          Sent from my Pixel 6 Pro using Tapatalk
