mpc4500 jam 56 registration off in adf
  • mrfuser
    • 1617
    Anyone seen this jam 56 in feeder?
    Kelly
  • COPIERMAN
    • Jun 2009
    • 559
    Re: mpc4500 jam 56 registration off in adf
    Try cleaning adf registration sensor area could be false jams. If trying to feed paper then jams you should look for mechanical problem or sensor issues.
    • Llama God
      • Mar 2009
      • 1353
      Check that the transport rollers just past the feed belt aren't spinning on their shaft. There are 3 of them, 2 thin ones and a thicker one, and the thicker one comes loose with time.
      • Moza
        • 232
        Check if the ADF has a black sticky pad on the blue guide, they were sometimes missed off causing j56
        • NeoMatrix
          Senior Tech.
          • 3513
          Attach the first page of the SMC report.
          SP 5990-4.
          I would be interested to know what the skew sensor count is logging.
          It may be a simple case of cleaning the original input sensor.
          HTH
          • NeoMatrix
            Senior Tech.
            • 3513
            Thanks Lama I have a dynamic fault problem child MPC3300 ADF at the moment I will check the rego roller and shafts next trip.
            • NeoMatrix
              Senior Tech.
              • 3513
              :: Better than a slap with a wet fish. ::
              J53 ERRORS for ADF 3030
              Replace Parts :
              A294-6700 Sep Clutch.
              D541-2241 Sep Roller
              AX21-0102 Pickup Mag Clutch
              AW02-0141 Input Photo Interrupter.
              B789-2114 Feed Belt Roller Oneway Clutch
              D541-2121 Feed Belt
              • Masterchief
                • Apr 2011
                • 280
                If the white torque limiter roller with the one way bearing is cracked it will cause slipping and jams, also the friction pads can be problematic also and these are worth changing
                sigpic
