Ricoh 1232C No network printing
  • biker_ted
    • May 2025
    I am trying to join a Ricoh 1232C on to my home network as a network printer. I followed the process of adding a new printer; assigning a new TCP/IP port being the same address as the copier/printer. I installed the necessary software on my PC, but it will not print - giving me an error message. Now.............I can print when my PC is directly connected to the copier via the parallel port, so the drivers must be OK. I can "ping" the printer on my network, indicating no firewall problems. I have added the IP address to my trusted list, but still no luck. Are there any further settings on the 107clear I need to amend? Any help on this would be most appreciative.
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    sorry to ask, but did you put in the subnet mask. ex:
    IP 192.168.1.10= Subnet 255.255.255.0
    sigpicWe can all Win, but at the end we all loose. Save the greyhound
    • Ollie1981
      Toner Monkey
      • Mar 2008
      • 418
      ..........but it will not print - giving me an error message.
      What error message are you getting?
      • biker_ted
        No network printing
        Hi Ollie - Yep, put in sub net mask 255.255.255.0. I read some where that the IP address could also not contain an address with the same prefix as any other on the network i.e. 192.168.1.10 as the address for the printer, so 192.168.1.100 could not be used as another address on the network.
        Hi iMind - just that : "there was an error printing to "Ricoh 1232 printer".
        • Ollie1981
          Toner Monkey
          • Mar 2008
          • 418
          When I'm testing NIC functionality on a customer's Printer/MFP, I usually set the IP addy on my laptop's NIC to one away from the MFP and connect to it directly using a crossover cable.
          For instance:-
          Printer I.P:- 192.168.1.1 Subnet 255.255.255.0
          Laptop:- 192.168.1.2 Subnet 255.255.255.0
          Most DHCP severs work in a similar way, assigning addresses in the same prefix range to all devices on the network with only the final digit being altered.
          On your home network have you manually assigned I.P addresses to every device on the network? Or does your broadband router/network switch have a DHCP server that automatically assigns I.P addresses to devices on the network? The printer does have an option to get it's I.P address from a DHCP server, but if you do that and tell the driver on your computer to print to a port you've created on a specific I.P address then it will only work until the "lease" has expired on that I.P address and the DHCP server assigns it another.
          If your network is small and only comprises of a few easily configurable devices, then it may be better to disable the DHCP server and manually assign each device an I.P address.
          To begin with though to eliminate only problems with the NIC in the Printer, I would get a piece of crossover cable and try and print to the device using the proceedure I detailed earlier.
          • _SuabE_
            • Jan 2008
            • 108
            "there was an error printing to" <-- this is usually when your system cannot print to printer that is on your list. but this is not your problem.
            You said that you can ping the machines ip address, this means the ip on your machines NIC is ok so the ip problem is not the issue.
            Now it seems the issue is the system interface between your NIC and machine system. I met this problem usually in Multi Functional Platform Copiers with a USB, LPT1, and Network.
            Take note that the driver for LPT1 and USB are different than the driver use in direct network printing.
            check this link for your drivers -->>Aficio 1224C/1232C download page
            If still you cannot print via network see if this option is installed in your machine
            RICOH AFICIO 1224C 1232C COPIER PRINTER & SCANNER KIT
            RICOH AFICIO 1224C 1232C COPIER POSTSCRIPT 3 BOARD
            If any one of this is not in your system you must provide to solve your problem
            sigpic
            Senior Technician Specialist
            A+; Network+
            Copier Brand handled: Canon, Lanier, Konica Minolta, Sharp, Ricoh, Kyocera Mita, Nashuatech, Ollivetti, Toshiba
            Printer Handled: Canon, HP, Epson, Brother, Samsung
            Duplicators: Risograph, Duplo
            • iMind
              • Mar 2008
              • 1116
              Maybe check if your router is registering IPs by Mac Address, suabE said that the drivers are different, its not the driver thats different but the port. You would be able to print even with out a post script board if that where to be the problem, you&#180;d get pages with caracters all over, but whats the error message: "can not print this page" something like that, try taking out the RJ45 from the router and ping your printer IP
              • _SuabE_
                • Jan 2008
                • 108
                Read his message iMInd he did print on LPT port, he can ping the ip of the machine but he cannot do print via network, did u experience this?
                sigpic
                A+; Network+
                • _SuabE_
                  • Jan 2008
                  • 108
                  i have 1 unit of this model with copier printer scanner kit installed, its working fine. with 300k copies 90&#37; color
                  sigpic
                  A+; Network+
                  • Mr Spock
                    Vulcan Inventor of Death
                    • Aug 2006
                    • 2064
                    I am not trained on this so take that under consideration.
                    If the machine has a built-in webpage then type the ipaddress into a web browser (internet exploder, firefox...etc) and see if anything comes up.
                    If it does then it is a driver issue. This could be anything from the wrong driver (ps vs pcl) to a misconfigured driver (lpr port number or wrong print queue name such as "print" instead of "Print"). Usually (on the machines I am trained on) lpt1 does not require a special port on the machine, while lpr does require one.
                    If the webpage does not come up then it may not have the option to print(via network) installed.
                    • iMind
                      • Mar 2008
                      • 1116
                      Mr. Spock had and exelent idea try it out. I think the default user for admin is:
                      try, administrator password= password or admin password null (blank) no password , in older machines they were sysadm and password=password
                      • _SuabE_
                        • Jan 2008
                        • 108
                        As i told you this model is a MFP Copier, Printing is only an options. IF you bought this Unit with a printer/scanner kit you should have the CD included with the package (Smartnet Monitor, Desktop Binder, and Scanrouter)
                        Even you access the web base user interface you cannot use the Network printing features (only stand alone via LPT) unless you install the printer/scanner kit, I install this unit a year ago. in TOTAL C.P.T.L. as network printer they use this scan to email and also scan to folders. Its happened to me guys .
                        sigpic
                        A+; Network+
                          • 22936
                          I also have never worked on this Ricoh. There are several other reasons why it might not print.
                          Job Accounting Code may be enabled. Only a print job containing the job accounting language would be allowed to pass.
                          I agree with the various other contributors that said that this was a port or driver issue. Emulation must be set correctly, of course, but if it was set incorrectly or it was the wrong driver you would get hundreds of pages of code not the print job. (You would get something.)
                          Is there a web page? Enter the IP address into your browser then Enter. (i.e.: http://192.168.1.10/)
                          This will confirm if you have a viable print card and connection. No driver is required for this.
                          • iMind
                            • Mar 2008
                            • 1116
                            • biker_ted
                              Ricoh No print
                              Wo! So much to take on board and try! 11.00pm here in UK and I'm off to bed. Will investigate and try on Monday.......will keep you informed!
