It seems Scan to SMB will not work with Windows 8 and Server 2012. I thought it might be usefull to share.
Scan to SMB to Windows 8/Server 2012
Re: Scan to SMB to Windows 8/Server 2012
Thanks Eric. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Thanks, Eric.
I wonder if that means SMB printing will fail as well.โI think you should treat good friends like a fine wine. Thatโs why I keep mine locked up in the basement.โ - Tim HawkinsComment
Originally posted by coltrainNeed to upgrade the firmware to use it....
Did you even read the article Eric posted?
It doesn't work, and there is no firmware yetLast edited by sandmanmac; 11-04-2012, 03:52 PM.Comment
Originally posted by coltrainNeed to upgrade the firmware to use it....Comment
wkpowers83
I'm having the same issue with a TOSHIBA e-STUDIO455 and a TOSHIBA e-STUDIO556. Does anyone know the actual reason why this isn't working?
Thanks,
KaseeComment
Windows 8 uses SMB version 3, most devices are built on SMB version 1 and 2. Version 3 is supposed to be backwards compatible, however most devices running versions 1 and 2 don't have that functionality enabled, or do not understand the newer protocol entirely.Comment
rberry3000
this is actually a problem with the new APPLE O/S as well. it seems the new O/Ss have changed some security issues in SMB which makes legacy products incompatible. Have to use FTP for now until firmware updates come out for your machines if they do.Comment
wkpowers83
That's what I did as well. FTP works.Comment
