Scan to SMB to Windows 8/Server 2012
  • Eric1968
    • 2458
    It seems Scan to SMB will not work with Windows 8 and Server 2012. I thought it might be usefull to share.
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: Scan to SMB to Windows 8/Server 2012
    Thanks eric1968 for the info.. Freakin MS Aholes did it again!!!!!!!!!!!!!!!!!!!!!!!!!!
    Mystic Crystal Revelations
      • 22999
      Thanks Eric. =^..^=
      • JR2ALTA
        • Feb 2010
        • 2030
        I'll withhold judgement till TheOwl weighs in..
        • icese
          • Oct 2012
          • 8
          Thanks eric
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            Thanks, Eric.
            I wonder if that means SMB printing will fail as well.
            • billm
              • Jun 2012
              • 50
              thanks for the heads up are we waiting for firmware or just moving on
              • miro
                • Feb 2010
                • 87
                good info
                thanks
                • havokprod
                  • Oct 2012
                  • 159
                  Good to know. Thanks
                  • sandmanmac
                    • 3979
                    Originally posted by coltrain
                    Need to upgrade the firmware to use it....
                    Did you even read the article Eric posted?
                    It doesn't work, and there is no firmware yet
                    • Eric1968
                      • 2458
                      New Network firmware is scheduled to be released in january 2013 for the latest models. For the models with GW-Controller 05A and earlier, there will be no firmware update available.
                      • wkpowers83
                        I'm having the same issue with a TOSHIBA e-STUDIO455 and a TOSHIBA e-STUDIO556. Does anyone know the actual reason why this isn't working?
                        Thanks,
                        Kasee
                        • ruben
                          The New Guy
                          • Oct 2012
                          • 1203
                          Windows 8 uses SMB version 3, most devices are built on SMB version 1 and 2. Version 3 is supposed to be backwards compatible, however most devices running versions 1 and 2 don't have that functionality enabled, or do not understand the newer protocol entirely.
                          • rberry3000
                            this is actually a problem with the new APPLE O/S as well. it seems the new O/Ss have changed some security issues in SMB which makes legacy products incompatible. Have to use FTP for now until firmware updates come out for your machines if they do.
                            • wkpowers83
                              That's what I did as well. FTP works.
