ricoh mpc2051 ,when printing image repeats.
  • tullio
    • Feb 2012
    • 268
    ricoh mpc 2051, 2012-12-28 14.55.16.jpg replaced un2012-12-28 14.55.51.jpgits' merger, same problem. the mpc 2051 and 'new.
  • ruben
    The New Guy
    • Oct 2012
    • 1204
    Re: ricoh mpc2051 ,when printing image repeats.
    What paper are you using? If a thick type make sure you are using the correct temperature settings. Also, check the fuser pressure roller, it may need replacing or it's levers may need adjusting.
    (Better yet, what are the current PM counts?)
    • Exok
      • Jun 2011
      • 750
      By the photos, it looks to me like the problem is in your fusing unit. Check the condition of the upper fusing roller. (Teflon coating is in good condition) Also make sure that you have good pressure between the 2 rollers. If you have a worn / broken bushing or bearing it can cause a loss of pressure between the 2 rollers giving you the same symptoms. Make sure the pressure springs are installed correctly and the pressure spring levers are in the correct position.
      • eric
        • Oct 2010
        • 25
        hello
        for this pb,if you have that just after warm-up and if the fuser is ok.
        clear nvram 5.801 and re-enter the non-defaut data (sheet in the door)
        amizing,but it works
        • nobody-here
          • Mar 2008
          • 237
          Ciao Tullio,
          did you solve the problem?
          Was the fuser or other reason.
          Ciao e grazie
          Originally posted by eric
          hello
          29 rouge unpair manque.... cous cous....
          • Eric1968
            • 2458
            Originally posted by nobody-here
            Ciao Tullio,
            Ciao e grazie
            And the one and only thing you really shouldn't do is a NVRAM Clear!
            • Herostrat
              • Oct 2012
              • 220
              Culd it be "for use" toner causing that mess...can you feel the texture of print under your fingers?
              Make shure that image formation sections are in good shape before working on fusing unit.
              Reseting collor machine is never a good idea...going back on initial values with reentering them from birth certificate may be a temporary solution...aside the fact that all other assemblys may cause even more mess.
              Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
              • joshuadenmark
                No NV ram clear!
                It is a fusing problem as stated above.
                  • 37628
                  I have seen this problem with low end models. Looks exactly like fuser offset but is actually from the PCU. The models I had trouble actually had drum and hot roller diameters that were very close.
                  • yianni
                    • Jan 2013
                    • 42
                    It helped me out. I replaced the fuser and it was fixed, thank you!
