Ricoh 1013 jam A
  • ash_572
    • 523
    Ricoh 1013 jam A
    Intermittently jams at a. Mainly stops at the fuser entrance (before going in to the fuser)
    I replaced the fusing exit sensor. Also jams at bypass too same place.
  • Eric1968
    • 2458
    Re: Ricoh 1013 jam A
    Try to adjust the cover switch. Happens often with these machines.
    • ash_572
      • 523
      Wheres the cover switch?
      • ash_572
        • 523
        If it's the door switch then why is it showing jam a and not "close door"?
        • 41-willys
          • May 2010
          • 36
          check the transfer roller on the side door, have seen the gear go bad or the roller out of place
          • ash_572
            • 523
            Transfer roller and gear is ok
            • cdog530
              • Nov 2009
              • 66
              Dirty paper feed clutch / registration clutch?
              -C
                • 37502
                Door switch opens momentarily during a copy. You might get a beep but the fakse door open condition does last long enough for the light to come on. When the door is detected as open all motors stop. When the door is seen as closed again, paper is at a sensor and is detected as a jam. There will be no jam logged in the jam history. Depending on the MFP model, you might get jams at power counts in the jam location counters.
