Aficio1022 - Error Code SC541.....then Error Code SC542
  • ritchiewheeler
    • Jun 2025
    [Error Code] Aficio1022 - Error Code SC541.....then Error Code SC542
    I've been working on a Ricoh Aficio 1022 copier. The fuser unit gave me an SC541 error. So, I replaced both thermisters in the fuser with new ones (verified correct OEM MPN.) Then, after clearing all error codes from memory, I rebooted machine and received SC542 error code. Whats up with this?
    I checked both heater elements inside the fuser drum, but they both appear to be okay. There is no visible evidence of worn bearings or anything out of the ordinary except excess toner stuck to the "feelers" that are spring-loaded against the fuser drum. These I cleaned, but no help.
    Any ideas?
    Ritchie Wheeler
    • 37375
    Re: Aficio1022 - Error Code SC541.....then Error Code SC542
    Open thermostat, loose connection, or open fuser lamp. When detected during operation, it will give SC541. When detected on power, SC542.
    • sandmanmac
      • 3979
      Questions:
      1: When you say you "cleared all error codes". Do you mean that you ran SP7807?
      Because it doesn't actually clear the current SC, it simply resets the SC History on the machine.
      SC5810 resets the SC
      2: When you checked the lamps, do you mean for continuity or just visually? They are either good or not.
      • Blizzoo
        • Aug 2013
        • 607
        Hit the thermostat on the table if is open circuit and should work-just for testing purposes
        • ritchiewheeler
          Checked & cleaned all contacts in fuser. Checked DC resistance of thermisters @ contacts where fuser plugs into copier: both about 430 kOhms. Also checked DC resistance of both drum heaters: both about 2 Ohms.
          Is fuser lamp(s) the drum heaters? Also, what is the thermostat you refer to?
          • ritchiewheeler
            Originally posted by sandmanmac
            Questions:
            I ran SP5801 & SP5810, then turned unit off for >3 seconds. Checked lamps with continuity meter: both checked good.
            • ritchiewheeler
              The best I can figure is that 1 or both thermisters is/are bad. Considering that I ordered them from [cheap] Hong Kong, this may be the case?
              • Richariri
                • Dec 2013
                • 163
                Yes.
                and this Link will show you an image of the thermostat... It is basically a thermal fuse.
                Part number for the 1022 thermostat is B0274095, although you can reset the thermostat by giving it a sharp WHACK off a table.
                If the thermostat is concave it has been tripped... convex and it is ok
                Hope this helps
                • ritchiewheeler
                  Originally posted by Richariri
                  Yes.
                  Hope this helps
                  Well, here's the story: 2 out of the 4 thermal fuses were tripped. While I was diassembling fuser, I noticed a lot of frayed & broken plastic inside (mainly around the rollers.) I put the fuser back together & crossed my fingers. STILL getting SC542 err. I've gotta funny feeling I'm going to have to replace the whole fuser in lieu of all the damage to the plastic frame inside.
                  Any recommendations as to reliable replacement outlets & estimated costs?
                  P.S. - You guys did a GREAT job leading me through this troubleshooting!
                  • gear13z
                    • Sep 2011
                    • 68
                    double check your thermistor if it is contact with hot roller, sometimes this things, often forgotten..
                    .....with all it shams, drudgery, and broken dreams, it is still a beautiful world.....
                    • ritchiewheeler
                      Double-checked all 4 thermal fuses individually & collectively with ohm-meter. The series of all 4 fuses was way less than 1 ohm.
                      • jtd55
                        • Dec 2013
                        • 30
                        Sounds very much like upper fuser frame has gone this machine & others are prone to it !!!
                        • ritchiewheeler
                          Double-checked thermal fuses: checked OK. Did some poking in service mode -- SP mode 2220 (Vsg/Vsp/Vsdp/Vt/Vts Display) --
                          every one of these voltages shows 0.00???
                          Should these voltages show 0?
                          If not, is this power supply problem?
                          • johnyb
                            • Feb 2011
                            • 167
                            Its easier to use blu tak to pull the face of the thermostat back into position.
                            That way you dont destroy the stat by hitting it too hard! (like I have in the past)...
                            Obviously to be used fir testing purposes of course! !! :-)
                              • 37375
                              This usually means a problem with the Image Density sensor.
