MP 5001 BACK GROUNDING
  • Technico
    • Feb 2013
    • 9
    Re: MP 5001 BACK GROUNDING
    also ....clean copper bushings before you put charge roller back into pcu ...had many times causing background ...it should help you
    • digicor
      • 1158
      nice thanks for the heads up on the dv rollers
      and the charge bushings i clean anyway
      • nmfaxman
        • 1702
        Set the doctor blade to .35mm.
        You may have too much of a brush on the mag roller.
        Seen these come out of the factory@ 1.00 mm.
        • digicor
          • 1158
          #19
          nice clue, i bet this is the eternal prob with machines in the first place,
          will do,
          this sounds more like a good fix for afactory oversight
          thnks
