Baron Pro 8100/8110/8120
  • monkees
    • Jan 2011
    • 40
    #31
    Re: Baron Pro 8100/8110/8120
    disassemble and clean well all the fan ducts
    replace all filters
    Developer how many prints produced?
    • Di$c0
      • Aug 2009
      • 25
      #32
      the developer had 1.1 million on it, just changed it. Updated firmware and cleaned filters... i blow out the ducting next visit.
      • rexrotary
        • Feb 2015
        • 19
        #33
        Hi Guys,
        I have installed PRO8120S allmost two weeks reading 5.6k .Please can your give me tips to replace 600k kit.And also sp reset mode.
          • 37490
          #34
          Originally posted by rexrotary
          Hi Guys,
          Just follow the service manual exactly. If you don't, you are asking for major problems. As far as clearing the PM counters, do so in system SP with the door open.
          • Di$c0
            • Aug 2009
            • 25
            #35
            replace all filters
            Ventilation is very important on this machine, i tore the ducting down all the way on the first one to familiarize myself (full of toner) , second one i just hit the 3 fans and filters. Thanks Monkee
            • anothertech
              • 1769
              #36
              How long do the feed rollers last?
                • 37490
                #37
                Specifications: 1M. In actually, depending on paper surface and lint content: 600K to 900K. If you start getting a lot of feed jams prior to that with the center of the lead edge dented by the reverse roller, replace the feed and reverse rollers with AF031040 and AF032040. They are for older model 60-80 ppm models and speced at 300K but with proper cleaning will last 500K to 600K. Paper dust is easier to clean off, near impossible with the 1M rollers.
                • melmar
                  • Aug 2011
                  • 43
                  #38
                  Hi All
                  Ive got a Baron with 7Million on the clock and I'm getting wandering registration on the lead edge. I have rebuilt the reg area with new gate reg rollers etc but the reg is still not aligning correctly.
                  can any one help.
                  • gaudin
                    • Mar 2008
                    • 39
                    #39
                    Hi,
                    not my expirience but form other techs... the feed roller need to replaced early/often.
                    But i like the printing quality of the 8100 :-)
                    Certified for:
                    Compita A+ / N+ / S+
                    Microsoft MCST / MCA
