I started out by replacing the lower pressure roller, the cleaning roller, and the upper fuser roller as they looked worn in the place where the line was and it was time they were replaced according to the service manual. That didn't fix the problem.
I also replaced the drum as that looked worn in the place where the line was and it didn't fix anything.
This multiplied my problems now as I get grey copies and dark edges sometimes. It also appears that toner escapes inside the machine, which would indicate a bad seal between some of the parts, but I don't see one.
The machine also sometimes throws a SC304 error, but I believe this is in due part to the above problem.
From my understanding the grey copies, white lines, and dark edges can be caused by a dirty main fuser wire or corrona. Unfortunately I'm not able to locate it in the service manual to clean it or have any idea where to start looking for it myself.
Any help would be much appreciated.
