I ran into this yesterday and thought I might share this as a tip because SC990 has so many solutions.
This was a Gestetner DSm635. The first think I noticed was that the 990 was occuring at the end of a run, no matter what size. As this model makes a patch at the end of a run, I changed SP2208 to one to change it to pixel mode and prevent the patch from occurring. No more SC990.
Next I looked at the most likely culprit, I checked the values of SP2103-1 and -2. These are the current indications for the Laser Diodes, they should be low, on this model I think about 10 or 20. They were all the way up to 65. The laser was working too hard.
This told me that the door switches were loaded with toner.
It most likely was the ones on the upper right but I decided to cover all the bases and replace them all. The ones in the lower left are easy to get to but rarely have a problem, the ones in the upper right are a pain in the ass to change but sit within a few inches of the toner spray-o-matic system.
So I changed them all and problem solved.
