ricoh mpc3500 with yellowish orange line in same spot intermittent
  • NeoMatrix
    Senior Tech.
    • 3513
    #16
    Re: ricoh mpc3500 with yellowish orange line in same spot intermittent
    Originally posted by twokoop
    Yes I cleaned every inch of the optics except laser unit
    I understand. If the line enlarges or reduces the fault is in the optics.
    Not to flog a dead horse... I've had dirt and grit on the optics that only 100% alcohol could remove.
    One job drove me up the wall. I knew it was optics an only pure alcohol fixed the issue. I must have cleaned those mirrors five or six times with water trying to fix the error.
    Re Dev void:
    Wind the dev roller backwards slightly an shake to eject the lumps. If the line moves to another position you know it's a doc blade Dev void. If the lumps can be seen touch a magnetic screw driver on them to remove the lump.
      • 37489
      #17
      OK Not to familiar with this model..I see there both located on the left side ..??
      If you have the service manual, the detailed descriptions portion has a good view of the laser projection paths.
      Had you included that image with your first post, we would have been able to offer more precised help from the start.
      • Polarbear
        • Feb 2012
        • 1070
        #18
        I could not find the proper SP mode number. Do you know what sim number it is?
        5618 [Color Mode Display Selection]
        Main SP Tables-5
        511001
        - *CTL
        [0 or 1 / 1 / 1/step]
        0: ACS, Color, Black & White, Two
        Colors, Single colour
        1: ACD, Full Color, Black & White
        Set it to "0" then you can choose single colour in the main copy window.
        Remember to set it back as it will confuse the customer BIG TIME!
        Press the GREEN button!!
        • Debs1964
          • Oct 2010
          • 1693
          #19
          I do not see a yellow line. What I see is a line where cyan and magenta are missing. Clean the doctor blades in the DV units and the laser shield glasses. The problem could be in the laser unit as both of those colors use the same (lower) laser.
          Cyan dev unit, doctor blade contaminated...that's what my money is on
          There are 10 types of people in this world, those who understand binary maths and those who don't
          • mikadonovan
            • May 2008
            • 2931
            #20
            Sp 2109. Use pattern 17, horizontal belt, and print one for each color. This will tell you what unit has the issue.
            NEVER ASSUME ANYTHING
            • sandmanmac
              • 3981
              #21
              It's a bit embarrassing to admit, but I never thought (or knew how) to select single colours for the test patterns .
              I always just enabled 'single colour mode' on the machine, and made test copies that way too
              Thanks Mika. Very useful!
              • logrady2331
                • Feb 2011
                • 301
                #22
                My guess would be the slit glass. If you are not fimilar with Ricoh color you might not know what the wand is for under the front door. Should be pretty easy to troubleshoot by just getting a visual on the dev. rollers once dissassembled.
                • Debs1964
                  • Oct 2010
                  • 1693
                  #23
                  Me too
                  • sandmanmac
                    • 3981
                    #24
                    Originally posted by Debs1964
                    Me too
                    Thanks for sharing Debs. If that's the case, I feel much less foolish
                    • twokoop
                      • Sep 2014
                      • 19
                      #25
                      What everyone is missing in this thread is that the line only happens on full color picture prints from the computer ..I have tried and replaced all process components and cleaned every inch of the machine ...ONLY ON FULL COLOR PICTURE PRINTS FROM COMPUTER
                      • Gift
                        • Mar 2011
                        • 2459
                        #26
                        Providing a sample image - always a good idea^^
                        This might be an obstacle/clogged toner inside a DV unit (probably cyan) or on one of the the laser glasses. The line is appears because a colour is missing wthin a small band - nothing fancy..
                        • Debs1964
                          • Oct 2010
                          • 1693
                          #27
                          Sorry, that still looks like a cyan dev unit problem to me, have you tried doing cyan sky shots, that absolutely does not look like a printing only fault
                          • Iowatech
                            Not a service manager
                            • 3930
                            #28
                            Then it is likely that the software producing the image is to blame. Or the person who created the image in the first place didn't do a very good job.
                            That's really weird, too. Any chance you could let us know what software was used to create the image? The only thing I can think of is that Adobe Acrobat requires people to think, and punishes those who do not. But I don't think that is the case here.
                            • Oze
                              Ricoh Fanboy
                              • Jul 2008
                              • 1663
                              #29
                              Yep....looks like a void to me
                              • CRISTIAN MULLER
                                • Feb 2013
                                • 145
                                #30
                                I had a similar problem on a MP C600, when i change transfer belt, a little hair from my brush stick to a roller under belt, after try swap everything e waste like 2 days, I open transfer belt unit and there is a m**her f**ker brush hair, I clean it and at first test, all good, almost cry with happiness that day.
