ricoh 1045 gremlins?
  • hodgiepodgie
    • Jul 2008
    • 284
    ok got a 1045 ricoh ran flawlessly for 6 mo.customer runs anywhere from 10,000. copies per month to 10,000. a week.he runs a job maybe 500 to 1,000 copies runs great no jams.comes back the next day jams right away.after multiple jams starts running again all day no jams.comes in next day jams . jam hist says fuser exit jam. paper jams in multiple copy mode not in single copy.does not matter if duplexing or not .RR feed clutch and tires.cleaned sensors rr fuser unit.no varying reg visible on copy.seems like a timing issue.so it will jam up then for no apparent reason will start running again.
  • Ricoh-ono
    • 338
    When was the pressure roller last replaced? Have you turned on fuser idling?
    Do what you can, with what you have, where you are. ~Theodore Roosevelt
    • iMind
      Vacuum Cleaning Expert
      • Mar 2008
      • 1116
      Hi Sir, listen take off your scanner unit, easy, take off cover on top of the fuser to access the top of the fuser exit, take it out, easy, on this assy there are two solenoides that have a cushion that is forcing the fork gate to get stuck, take them out and clean the sticky tape off, put it back in and you back in business.
      thats more likely to happen in duplex, and in the first morning copies.
      The PDF is not for that machine but its almost the same, its just for you to locate the two cushions, #9 on the rear side
      Good luck,
      Keep well.
      • iMind
        • Mar 2008
        • 1116
        thats going to cost you another fishing run.
        Theres always a Paul looking after a Paul, LOL
        Oh forgot to say the machine is going to be a little noisy, no problem if your client is a little def, hehe
        the machine will work no problem, if you wish just order new cushions and go back and put them in.
        by the way, I´ve got dogs that look like gremlins, hehehe
        French bulldogs, google it.
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          Ditto the solenoids, also the paper sensor inside the bridge unit is a culprit. BTW the 1045 is a gremlin!!!!!!
          Mystic Crystal Revelations
          • schooltech
            School District Tech
            • Jun 2008
            • 504
            If you haven't done it yet, yank the scanner assembly off, like iMind says, and clean & inspect all solenoids, sensors and inspect gate operation. This is an oddball area of the copier that rarely gets looked at by techs.
            You will probably find your problem in there. This fixes a lot of weird fuser-jam problems.
            Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
            • thekeg19
              • Jul 2008
              • 29
              i echo sentiments on gate solenoids, especially if duplexing, but i believe there was a tech bulletin regarding fuser exit sensor. also maight clean relay clutch if you have not yet. good luck
              • FRIDGEMAGNET
                • Aug 2007
                • 377
                Also look at the top of the fuser unit, there is a cutout that the exit sensor looks at - this gets dusty.
                • hodgiepodgie
                  • Jul 2008
                  • 284
                  fuser roller and hot roller new.maybe bearings but they seem ok .was in dallas fwew mos ago
                  • hodgiepodgie
                    • Jul 2008
                    • 284
                    [quote=iMind;35034]Hi Sir, listen take off your scanner unit, easy, take off cover on top of the fuser to access the top of the fuser exit, take it out, easy, on this assy there are two solenoides that have a cushion that is forcing the fork gate to get stuck, take them out and clean the sticky tape off, put it back in and you back in business.
                    Good luck,
                    well that is what i figured seems to be the only logical reason.was in process of doing that this morning will let you know.
                    • b003ace
                      • Jun 2008
                      • 78
                      sensor
                      Another problem that appeared in those machines was in the fuser exit sensor. They were too heat sensitive. There is a tech pub. But they usually caused the jams when hot, not cold. I also have seen the solenoid driving the duplex diverter gate in the exit section get sticky, but again, only when hot, not cold. Check that area thoroughly as others here have suggested.
                      • Lea@ABM
                        • Aug 2007
                        • 47
                        Thanks fridgemagnet
                        I had a machine that jammed just below the fuser exit sensor. After replacing the sensor and tearing off the solenoid cushions, it still jammed.
                        I finally fixed it by sliding out the fuser and cealing the little cut-out in between the middle seperators. This is where the senor in the invertor shines onto and hey prosto! fixed.
