Ricoh MP C4500 Shadow when printin or copying
  • feroo666
    • Dec 2014
    • 23
    [Dead] Ricoh MP C4500 Shadow when printin or copying
    After changing the ink when printing or copying out the picture under her often be double yellow and Writing (duplicate) like the picture attached Help me because maintenance engineers are asking for a huge sum of money seized
    i think i can solve it from the SP But I do not know how it's done
  • skynetto
    • Sep 2012
    • 257
    Re: Ricoh MP C4500 Shadow when printin or copying
    You either invest yourself in a service manual or hire a tech to solve your problems. In the service manual you'll find the procedure for laser calibration and all the other questions you have placed around the forum. Anyway check the 2-111 section for forced manual calibration.
    • feroo666
      • Dec 2014
      • 23
      i will try thanks
      • feroo666
        • Dec 2014
        • 23
        I tried but appeared message Faild
        • skynetto
          • Sep 2012
          • 257
          Check ITB status. If worn the pattern calibration would fail. Check ID sensor status. If dirty it would fail as well. Check black developer if out of life. The machine checks the other color in corrispindence of the black one. Clean laser window and remove laser shutter if present.
          After all these checks reset calibration setting as per procedure
          Copy SP: 5610-4
          Printet SP: 1101-1
          Copy SP: 3011-1
          Check results in 3012-1
          If all 1 begin forced laser allignment
          2111-3 once and 2111-1 twice.
          Check alignment with Printer SP
          1103-2
          If in the above step the results of 3012-1 are not all 1 check the remedy in the service manual.
          • feroo666
            • Dec 2014
            • 23
            Copy SP: 5610-4
            Printet SP: 1101-1
            Copy SP: 3011-1
            1103-2
            Followed all the steps but still gives an error message when I Check results in 3012-1 I see the counter 11111159
            then i see error message again faild
            • skynetto
              • Sep 2012
              • 257
              Error 59: Insufficient data for gamma correction. Check Black Developer status and ID sensor status.
              So you haven't done what I've told you to do.
              Conslusion: Buy a manual or hire a tech.
              • ali.alhaj
                • Mar 2013
                • 34
                Dear
                Find the sp paper in front door and filling the parameters and do 2111 line position c,b,a not a,b,c
                • Oze
                  Ricoh Fanboy
                  • Jul 2008
                  • 1663
                  PAY FOR A SERVICE...OR GO TO FIXYA.COM AND ASK YOUR QUESTIONS.......oh....and Happy New Year!!!!!!
                    • 37641
                    You most likely need to replace the image density sensor, the black drum unit and the black development unit.
                    • Oze
                      Ricoh Fanboy
                      • Jul 2008
                      • 1663
                      He can't do that Slim because...and I quote:
                      Bastard techs..trying to make a living and all
                      • bob marley
                        • Jan 2012
                        • 1339
                        Live for yourself and you will live in vain. Live for others, and you will live again
                        • turbojetboy
                          • Aug 2009
                          • 279
                          My guess is the machine has had a very recent memory clear, as the colour reg always goes out the window ( with a lot of other things) after a mem clear.
                            • 37641
                            I had a machine a couple of years ago, either a MP C4501 or C4502, that kept going out of color registration. Ran ACC and it pulled it back. Two days later, out of registration again. Cleaned ID sensor and ran ACC. A week and a half later, out of registration again. As it was less than 3 months old, regional rep came out and brought an ITB unit with him. Problem solved. It seems that the ITB belt will sometimes start slipping.
