Poor Copy quality On MP C6000
  • spgnet
    • Jun 2013
    • 16
    [CQ] Poor Copy quality On MP C6000
    Please advice poor copy quality on this MPC 6000 unit , which part need service
  • Bantams
    • Jun 2012
    • 603
    Re: Poor Copy quality On MP C6000
    1 Have you been Trained on it?
    2 Why was you trained on it?
    3 run the other way
    • anothertech
      • 1760
      I wish I wasn't trained on it!
        • 37357
        If you are referring to left edge of the print, I would clean the laser shield glasses. If that does not correct the problem, replace the development unit.
        • Zaxxon
          • 608
          Ha ha ha, me too
          Please start you post with brand, model, problem.
          • Zaxxon
            • 608
            [ATTACH=CONFIG]27934[/ATTACH]
            is it the black color only?
            • bob marley
              • Jan 2012
              • 1339
              agree with u
              Live for yourself and you will live in vain. Live for others, and you will live again
              • spgnet
                • Jun 2013
                • 16
                Color also...not only left side ..some time other side
                • Zaxxon
                  • 608
                  look at the PTR sektion, it can easily be assembled or mounted incorrect.
                  aaaaand follow the PM counters or this machine will kick your ass (probably will anyway).
                  • Cipher
                    It's not easy being green
                    • May 2006
                    • 1309
                    Intermittent blurs on K like seen in you sample can be caused by condensation build up on the drum surface.
                    Check the air flow inlets and exits, vac / clean all the filters as they do get clogged up quickly on this range.
                    • anothertech
                      • 1760
                      The OP says it's on color as well, if that's true then I'd be looking at the ITB area or jitter along the paper path.
                      • Hankster
                        • Jun 2011
                        • 18
                        Welcome to the world of ricoh!!
                        • Max
                          • Oct 2011
                          • 552
                          Just bin this thing.
