Color offset
  • jrob416
    • May 2011
    • 112
    [CQ] Color offset
    I have been dealing with an MP c3000 with a color offset issue. Tried to adjust with the service codes and had only short term success. Updated firmware, just for giggles and the off-chance, to no avail. What am I missing? Any help welcome. Thanks.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Color offset
    Do you have a sample? Offset is a very broad term, do you mean it isn't fusing correctly? Or, are the colours not aligning?
    • redneckstylin
      • Sep 2011
      • 173
      Re: Color offset
      if it is a 3d print like issue you need to do a cca forced line aswell as color regi
      • jrob416
        • May 2011
        • 112
        Re: Color offset
        Colors not aligning on top of one another. The sample my client showed me had small squares with the colors misaligned or offset on top of another. The fusing is fine, the colors are picked up in different spots on the transfer belt. Or placed on drum units improperly.
        • ruben
          The New Guy
          • Oct 2012
          • 1203
          Re: Color offset
          If you performed a forced line adjustment C then A twice, and it still isn't aligning properly, then you could have loose screws on the laser, faulty drums, loose drums, or faulty ITB.
          • bob marley
            • Jan 2012
            • 1339
            Re: Color offset
            try to attach sample
            Live for yourself and you will live in vain. Live for others, and you will live again
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              Re: Color offset
              In extreme cases i've had to do an Engine clear to fix this but that's usually 2800/3300/4000/5000 series rather than 2500/3000 series....might be worth a shot if you know what you're doing
              • anothertech
                • 1760
                Re: Color offset
                Don't even do it, only as a last resort! This is the Nuclear option. Tread carefully, thin ice. Danger Will Robinson, Danger.
