MP C4000 fuser not setting properly
  • ABS tect
    • Sep 2013
    • 511
    #16
    Re: MP C4000 fuser not setting properly
    Alright I will try these and let you know what happens
    • ABS tect
      • Sep 2013
      • 511
      #17
      Originally posted by PA3040
      check the following
      5803 Input Check
      046 Fusing Unit Set Set (Bit1) Not set (Bit1)
      Ok...in SP Mode 5-803-046 I cannot change bit 1, it is not letting me access it at all to change any of the numbers. Is there something you have to initiate to it to be able to change the bit no. ?
      • benalvarez
        • Feb 2015
        • 27
        #18
        I think a mp4000 printer fuser will work in the mpc4000, it is a lot cheaper, check it out for part compatiblility.
        • ABS tect
          • Sep 2013
          • 511
          #19
          PROBLEM SOLVED
          I switched the wire harness from the original onto a mp c5000 fuser. Fired right up. Thanks for all the help!
          • C.Vallon
            • Jan 2015
            • 70
            #20
            Ha, good to hear. Great job man. Sounds like we were all in the ball park, but just slightly off base. Keep it up man. Was a pleasure to watch this thread evolve into a successful closure.
              • 37493
              #21
              All item in SP 5803 are to look at what the input from the device is. If a value is showing 1 and it should be 0 then the associated device is where the problem is. In your case it turned out to be something in the wiring harness affecting the device reading.
