check the following
5803 Input Check
046 Fusing Unit Set Set (Bit1) Not set (Bit1)
Ok...in SP Mode 5-803-046 I cannot change bit 1, it is not letting me access it at all to change any of the numbers. Is there something you have to initiate to it to be able to change the bit no. ?
Ha, good to hear. Great job man. Sounds like we were all in the ball park, but just slightly off base. Keep it up man. Was a pleasure to watch this thread evolve into a successful closure.
All item in SP 5803 are to look at what the input from the device is. If a value is showing 1 and it should be 0 then the associated device is where the problem is. In your case it turned out to be something in the wiring harness affecting the device reading.
